7.3L Oil Pan - The Truth ? - Diesel Forum - TheDieselStop.com
post #1 of 34 (permalink) Old 06-18-2012, 06:47 PM Thread Starter
micp1991's Avatar
Yes, my oil pans leaking pretty bad, rusted pretty good in several spots (2002 7.3L, just turned over 290k miles). Saving some sheckles to have the motor pulled for the whole replacement project etc...
My question to youz guys way, way more knowledgeable than me is : how and why does this happen ?? Everyone Ive asked has a different answer. Some guys SWEAR that the 99-to early 2000s 7.3's all had a batch of defective oil pans (that Ford somehow damaged or left out in the rain or somehow poorly manufactured or something .....) and that they're rusting FROM THE INSIDE OUT, and some guys say that its just rusting from the outside in and is a design flaw.
[ How the hell could they rust from the inside out when they're coated in oil all the time ??? ]
Does anyone know the real deal?
Thanx ;-)
2002 F350 7.3L XLT Crew Cab Short Box; Stocker; 323,000 miles and going strong.
Guess I fall into the "High Mileage" categories now ...
micp1991 is offline
post #2 of 34 (permalink) Old 06-18-2012, 06:58 PM
klhansen's Avatar
My Photos: (180)
IT'S THE SALT THEY USE ON THE ROADS!!
There's no way they rust from the inside out. It may look like it, but trust me, it's the salt.
Because it's too cold to use salt up here, they use something else. The oil pan I pulled off my engine with the cracked block is in fine shape. There's a couple of tiny blemishes from rust up near the top, but otherwise it's totally sound.
), AIS,
regulated return,
klhansen is offline
post #3 of 34 (permalink) Old 06-18-2012, 09:32 PM
redcell6613's Avatar
My Photos: (19)
Send a message via Yahoo to redcell6613
Salt for sure, I'm in NW Jersey also. Plus I'm sure what type of surface you park on regularly can't help. I park on gravel that is covered from above all day by dense trees....after it rains that driveway is damp for days.
Klhansen.....Has anyone ever tried making an oil pan out of some other type of material?
2002 F350 Lariat LE Dually 4x4 Crew Cab 7.3L, 4.10 gears, GTP38-R, Stage 1's, Custom Tunes, MBRP exhaust w/ stacks, 11 ISSPRO gauges, F-650 lower dash, Oil / Coolant / Tranny bypass filters, S&B Intake, Marinco Mod, Custom hydroboost remote filter / reservoir system, HPX, FRX, Bilsteins and Mag-hytec Rear / Front Diff Covers, 6.0L trans cooler / power steering cooler, Pioneer touchscreen with Alpine speakers all the way around.
2005 Ford Excursion 4x4 Eddie Bauer Edition
6.0 Liter: EGR Delete, S&B Intake, Sinister Intake Elbow and IC Pipes, Gryphon FICM Tuner, X4 with Gearhead Tunes, Edge CTS Monitor, MBRP Exhaust, Bilstein Shocks and Stabilizer, ARP Head Studs, MBRP Exhaust
2015 Jeep Rubicon Unlimited: 3.5 Inch AEV Lift Kit, Fox Racing Remote Reservoir Adjustable Shocks, Fox Steering Stabilizers, AEV Rear and Front Bumpers, Prodigy Performance Stage 2 Turbo Charger and Injectors, Prodigy Tunes, AEV Wheels, Mickey Thompson MTX 35" Tires, Terraflex Bumps.
redcell6613 is offline
post #4 of 34 (permalink) Old 06-18-2012, 09:37 PM
F350_6's Avatar
Too cold for salt? I've never heard of such a thing. Of course where I'm from they don't use any salt on the road either. If it ices here, we just wait until tomorrow and it's all gone. We just stay home for the day.
No rust on my oil pan at 407,000 miles and my 99 didn't have any rust on it's oil pan either when it got wrecked at 100k miles. I agree, it's the salt.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #5 of 34 (permalink) Old 06-18-2012, 09:44 PM
My Photos: (19)
Ha ha you Texans are lucky.
In the North East keeping an oil pan and cab corners and rocker panels in stock at home is a must...lol
post #6 of 34 (permalink) Old 06-18-2012, 10:46 PM
klhansen's Avatar
My Photos: (180)
Not for a Diesel that I know of, but a lot of the smaller engines use aluminum. I know that a 2000 Explorer 4.0L has an aluminum pan, because I hauled one to/from the wrecking yard for another TDS member. IIRC my daughter's 94 Mazda PU has one as well.
Aluminum isn't a cure-all for corrosion though, it just takes a bit longer to rot thru because of the thickness.
), AIS,
regulated return,
klhansen is offline
post #7 of 34 (permalink) Old 06-18-2012, 10:53 PM
chuckster57's Avatar
In my 35+ years of being under hoods and engines, I can say I have seen very few oil pans that weren't steel. Seems to me it's just too easy for them to stamp 'em out cheap and fast.
Answered on my iPhone.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #8 of 34 (permalink) Old 06-18-2012, 11:09 PM
RT
RT's Avatar
The new 6.7 diesel has a composite plastic oil pan...
RT is online now
post #9 of 34 (permalink) Old 06-19-2012, 12:44 AM
klhansen's Avatar
My Photos: (180)
I did not know that. Makes some sense - at least it won't corrode.
), AIS,
regulated return,
klhansen is offline
post #10 of 34 (permalink) Old 06-19-2012, 05:16 AM
I have to admit, I've spent the last 15 years in the Lone Star state as well but I don't understand how it can ever be too cold for salt. I will tell you, having driven many miles in the cold northern region of this country, I learned quickly that you needed to rinse your truck frequently when traveling through those regions because of the chemicals they started put on the roads to inhibit the formation of ice. Whatever it is that they use nowadays will eat up your vehicle and many times I've had trailer wiring screwed up if I didn't rinse the grime off soon enough.
Ask any big truck driver (tractor trailer driver) who drives in those areas and they'll tell you that the chemicals put on roads today will eat your truck up.
Mike
Member #4,587
1999 F350 XLT crewcab 3 inch body lift, 8 inch suspension lift. Edge Evolution programmer. AFE cold air intake. 37 inch tires. Pics are in link below.
1996 F350 XLT crewcab dually, (RIP) pulled a 50+3' step deck trailer and 30' cow trailer.
Pictures of it's death can be seen in link below.
I PREFER DANGEROUS FREEDOM TO PEACEFUL SLAVERY-Thomas Jefferson
Remainder of signature deleted for political correctness violations
RopinandRidin is offline
post #11 of 34 (permalink) Old 06-19-2012, 08:16 AM
sd73man44's Avatar
Location: midwest, Tecumseh, MI, Standish Pond and River Raisin
oil pan rust
It was simply a cost decision to use a material that was less expensive than say a higher strength than what was chosen. The draw depth may have also been a big factor in the stamping process. Those plus a poor (e-coat) surface prep and the results are what we see on our trucks in the field. Material thickness makes a difference and maybe since Intl was the supplier their testing was not run out to a cycle equivalent to our usage (10+ years). Many test cycles are also run in a lab, which may not emulate our use profile. The around the clock test track never allows the components to go thru heat/cooling like we put them thru in our daily use.
Aluminum is not a solution because it corrodes just differently. Aluminum is used in cars for two reasons neither being corrosion. The first reason is structural to make the engine block stiffer for our front drive vehicle designs. The second reason is to reduce vehicle weight to improve fuel economy. BUT, cost is BIG. And when the cost reductions are demanded by management the customer is forgotten.
In my opinion the BIG mistake made by Ford was the failure to make 'design for service' a first priority.
'99 7.3L SD F250 4X4 manual 6 speed - original.
"We got a lot of stupid politician's in this country" C.S.
sd73man44 is offline
post #12 of 34 (permalink) Old 06-19-2012, 09:43 AM
When you make a vehicle the size of the F series and put an engine into it the size of the 7.3 Engineers have to make compromises. Get it in and make it work first, engineer for maintenance and service lower on the priority list.
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #13 of 34 (permalink) Old 06-19-2012, 09:52 AM
sd73man44's Avatar
Red face "Built Ford Tough"
Maybe "Built Ford Tough
means tough to work on!
Another comment on "Serviceability".
Many of the engineers tasked with designing today's products have never gotten their hands dirty or actually removed and replaced a component part for which they had the design responsibility.
I sprayed my oil pan with a product called CORROSION X to abate the rusting. It may help prolong the pan life but maybe I started too late. If your pan is in bad shape I would be careful poking or scraping it, just soak it down with a rust stop product to help slow the corrosion. The dip stick tube is also another part that is susceptible to rotting away. If you look at your dipstick tube and want to change it spray a penetrating "KROIL" or similar around the flange at the pan to loosen it up before you attempt to remove it from the pan. Many times it cannot be removed without damaging the pan, then you are in BIG trouble, and have to have the pan replaced.
The garage where I had some work done was pulling the cab off a F-350 (18 hour job) to replace the oil pan. They lifted the body on the hoist and rolled the chassis back and used a cherry picker to raise the engine high enough to remove the pan. This is no job for the inexperienced! The pan gasket is "Form in Place" and there is a critical time between when you apply the sealant to the part to when you slap it into place. Wait too long and the sealant will skin over and "then probably leak". Big job. Probably good idea to have a helper and use guide pins to place the pan accurately onto the cylinder block.
post #14 of 34 (permalink) Old 06-19-2012, 09:25 PM
klhansen's Avatar
My Photos: (180)
Consider that the triple point temperature of ice, salt and water is zero F. So if the ambient temperature is below zero (fairly common in Alaska), then the salt won't have any affect on the ice.
Can'd disagree with that. They use some pretty nasty chemicals. Back when I was working for the Air Force, I went to a Corrosion Control course at Wright-Patterson AFB in Ohio, and we estimated the cost of corrosion. Pretty eye opening, for sure. The instructor's favorite comment was about them using the "Free World's supply of salt" on the roads in Ohio. They've since branched out to use other nasty stuff as well.
), AIS,
regulated return,
klhansen is offline
post #15 of 34 (permalink) Old 06-19-2012, 09:27 PM
F350_6's Avatar
Do you folks realize that the guys with the newer trucks would love to have the kind of access under the hood we enjoy? Go look under the hood of a 6.4 and ask yourself if you think you could change the serpentine belt, much less something like glow plugs. The service manual actually calls for removing the cab on those trucks to do work on the engine.
Chris
F350_6 is offline
