7.3L oil pressure problems Help!!! - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 01-07-2010, 05:40 PM Thread Starter
Hey there. This is my first post and am hoping to get some help on the following problem. Truck is a 98 E350 powerstroke with 150,000 miles. Oil changes and filter every 5000 miles. My problem started with the truck dying after warming up. Found that the wires to the IPR were melted back and shorting together once the truck got hot. Found the problem and repaired the wires and the truck ran fine for a month. When I repaired the IPR I did an oil change, new oil filter, new fuel filter and new air filter.
1)Then I started to notice that she was smoking pretty badly when started but cleared up after a while. Smoke appears to be White when first started then blueish black in color.
2)Noticed a tapping sound coming from the drivers side valve cover. Very noticable with the breather hose removed.
3)Driving to work I noticed my oil pressure guage tank to 0, oil light came on and then pressure climbed and oil light went out. Pulled over and checked the oil level. oil level was fine but I did notice that it didn't have a clean look like it should have being recently changed.
4)Threw a scanner on the truck and received the following codes:
P1277 cylinder 7(c) - high to low side open
P1275 cylinder 5(F) - high to low side open
P0113 IAT circuit high output=KOEO self test fix second.
Continuous memory codes P0113 IAT circuit high input
Injector buzz test codes P1277 cylinder 7(c) high to low side open
My initial thoughts are to ring out all wiring harnesses pertaining to injector 5 and 7, open the valve covers, pull the injectors and replace the o rings (Would worn o rings cause my smoking problem and sudden drop in oil pressure?), test the injectors(primarily 7 and 5) (am I better off replacing them all while i'm in there?), replace the valve harnesses(I understand they are a problem on this model year), and replace the glow plugs while it's apart.
I would really appreciate any input that anyone might have as this is my first attemped at a project like this and I'm simply asuming that I'll find my problems with this course of action. I have read most of the posts pertaining to my issues. Thanks so much for the help.
sparkyblink is offline
post #2 of 5 (permalink) Old 01-07-2010, 09:23 PM
klhansen's Avatar
My Photos: (180)
Welcome to TheDieselStop
For your injector problem, its probably just the UVC harness loose on the passenger side. If it's running OK otherwise, the injectors themselves are probably fine.
Injector problems won't cause LP oil system issues. The PSD has esentially two oil systems, the LP system and HP system, with the LP supplying oil to bearings, lifters, and the HP system. The HP system boosts pressure and runs the injectors, which are little hydraulic pumps that are electrically controlled.
The LP oil pump is an internal rotor type on the nose of the crankshaft, and it runs between an iron oil pump cover and the aluminum engine front cover. Guess which one wears out over the other - the front cover. When it does, the oil pressure drops because it gets around the back side of the LPOP rotors.
There is another possibility, which is the oil pressure relief valve has a broken spring or otherwise won't close. It's down in the oil filter housing, and bypasses oil when pressure builds up at high rpms.
I'll be back with a link to another thread that should help you out.
on edit: check this thread out - low oil pressure after warm up
), AIS,
regulated return,
klhansen is offline
post #3 of 5 (permalink) Old 01-07-2010, 10:06 PM Thread Starter
Thanks so much for the information. I'll be sure to check the connectors on the passanger side VC's to be sure it's connected. I have noticed that the truck is running a little rough. Would the loss of (2) injectors cause the engine to run rough and cause excessive smoke. Also because the wires on the ipr had melted back, could that be the cause of the oil pressure loss issue.
The other thing I noticed was that the oil that was recently changed seemed very dark like it hadn't been changed in 20,000 miles. Thats why I wondered if the injector seals were going bad.
I also noticed a tapping sound coming from the drivers side valve cover. Could that be oil related as well. Sounds like a lifter or pushrod.
I assume the correct action would be to install a manual pressure guage on the oil resevoir to get actual readings. The assessment in the post that you sent was correct. The oil pressure changes when it warms up after about 5 miles of driving.
Thanks again for your time.
post #4 of 5 (permalink) Old 01-08-2010, 03:35 AM
klhansen's Avatar
My Photos: (180)
Definitely.
Possibly.
The IPR is associated with the HP oil system, so wouldn't reallly affect the LP oil system that much. If your repair isn't up to snuff, it may be causing some running issues. The HP oil pressure regulated by the IRP drastically affects how the engine runs.
I don't think injector seals will cause oil to get dirty quickly. How long had it run before you changed the oil? If the old stuff was really gunky, the 2-3 qts left in the engine (HPOP reservoir and injector oil galleries in the heads) would color the new oil pretty fast. Some guys advocate sucking the old oil out of the HPOP reservoir and refilling with new during an oil change. Can't hurt, but not really necessary, IMO, with normal change intervals.
That's what I'd do to see for sure what's going on. As I said in the other thread, the gauge is basically 2-position, not a true gauge.
), AIS,
regulated return,
klhansen is offline
post #5 of 5 (permalink) Old 01-06-2017, 12:31 PM
Thumbs down same problem
I believe that i am having the same thing happening with my truck. Low oil pressure and high IPR duty cycle but otherwise the truck seems to be running strong. Mine happened after i replaced all 8 of my injectors and paid Joey for the T500 mod to my HPOP. I am still hunting two 1277 1271 High to low side open check engine codes and a p1316 of course. So far i have replaced my the two problem injectors again and no change. I also replaced both UVC gaskets. No change. Ohm tested all 8 injectors and wiring harnesses down to the IDM all giving me 3.5-3.6 ohms. By the way i understand it though with AC current running through the Injector harness two wires next to each other and still ohms test proper but while the truck is running it will be firing two injectors twice per revolution (4 times since they are split shot) and be robbing two much oil for the Oil pump to keep up with and of course giving a misfire code on 1 and 7 since the injectors don't have enough dwell time to refill with oil and fuel. So my next step is going to be pulling apart the wiring harness and fixing injector wires. I hope this helps. I will keep you posted with my progress.
Splitter16 is offline
