Hi
So I rebuilt my 7.3l
since rebuild, truck will run fine for a couple of days then it will stall, let it sit it will run fine for a day or too, then stalls. Had ford Change cps run fine for a day stalls. so I checked low pressure oil its good, pulled out icp to check high pressure oil truck fires up idles at 1500 psi.will idle for long periods of time (couple of hours fine) go to drive it runs good for a day then stalls. unplug icp truck fires up.... do the next logical thing change ICP does the same thing runs and stalls. unplug icp fires up any ideas?? where to look next ????????
thanks for any ideas
