911 Help (thanks Guys all fixed great advice and accurate)
Husband needs help on highway black smoke coming out of exhaust EGT temp rising and able to stay at 1000 can't power up or temp rises on EGT.
All other gauges fine
Fuel consumption doubled, limping into town at 55 mph
comments please for help ASAP
f-350 2001 7.3 superduty 268000 km
DP chip with F5 switch and tymar intake
4" exhaust with cat delete and Pilar mount gauges
True cool tranny cooler 44'000
[/ QUOTE ]something blocking off the turbo maybe???some one chime in. but first pull over and shut it down. ur gonna blow something up.
I will forward the info if you have any other suggestion please continue to email.
He has stopped and is at a repair place but still looking for help.
Could the turbo have just died? No power and high EGTs, lots of black smoke... it really sounds like an air supply issue to me, but I can't be certain. I'm sure others with more experience will chime in here.
It sure sounds like and air supply problem. As Dieselman suggested, have him inspect the intercooler boots (there are 4 of them and are likely blue in color) and make sure they are on and secure. If they are on have him look to make sure there arent any holes where air can leak out.
This sounds like it came on quite suddenly but have him check the air filter as well. Always start with the most obvious and then get more complex....
'99.5 F250 Lariat 4x4 7.3L PSD, Crew Cab, Short Box, Auto, 3.73LS, Mastercraft Courser C/T LT285-75-R16, Magnaflow 4" exhaust with 3.5" DP, 6637 open filter intake, AutoMeter Sport Comp pillar mount gauges, DP Tuner F5 with 40t, 60t, 80econ, 120race, Hella 550 driving lights, Tru-Cool Max tranny cooler, 205k miles, HD4R100 tranny, Zoodad. Airbags on back, leveling kit on front.
My husband got to the dealer and the tested indicated it is probably the MAPP sensor (but they are not certain) they don't have one in stock but indicated that it is safe to get home slowly.
Will keep you posted and thanks a million for the little women at home.
Thanks guys>> It turns ouy it was not the mapp sensor but the mech did not check the intercooler hose very well and after installing the new mapp senser I found out that was wrong and took it to someone I new and found it at a glance (I'm so embarrased) I thought the mech checked it .
Builds us up with a lot of suspense and then just leaves us hanging until next season.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
sorry guys my life is just to busy !! Thanks again for the help and you were rite it was the upper intercooler hose burst dead center just hidden under the rad fluid res. its funny though the mechanic was right there when I told him what you guys said and he said yes I checked them and they are ok. the other guy just looked for two seconds and seen it. of course I trusted the other guy and didn't look my self. it was rite there ..
Andy
