99 7.3 psd engine shutter/miss - help - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 01-12-2009, 10:19 PM Thread Starter
engine developed shutter/miss recently, seems to be most noticable around 1500rpm. checked vc wiring harness and found one to be partially disconnected under passenger side. replaced gaskets and wiring harnesses on both sides but shutter/miss is still there just not as severe. did buzz test on injectors and tested fine. cps was replaced under recall about a year ago. the biggest problem that has me stumped is that its not showing any codes! any advice or suggestions would be greatly appreciated.
harleyman125 is offline
post #2 of 16 (permalink) Old 01-12-2009, 11:18 PM
tattoocharlie's Avatar
My Photos: (5)
maybe compression check?just thinking out loud.make sure cylindres are good,awhile back mine devolped a shudder.which got alot worse.turned out to be cracked piston.good luck,i hope its something simple
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #3 of 16 (permalink) Old 01-13-2009, 07:20 AM
JimTJr's Avatar
My Photos: (20)
When I had an injector go bad, it did just that. Passed the "Buzz" test, but failed the CCT. (You have not had those done yet I assume) But the symptoms were just that. Shudder at mid range RPM, under light acceleration. Do you think you have even the slightest miss at idle? (IF your straight piped it's SOO much easier to tell LOL) You can pull the valve covers, plug the main harness back in, and unplug each injector one at a time. See if the idle does not change for one of them. IF that's the case that is your bad one.
Not saying for SURE that is your problem. But my 99 did just that, it was my first diesel, and I didn't know what to think. Took it and had it diagnosed, then replaced it myself. Not terribly hard.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #4 of 16 (permalink) Old 01-13-2009, 01:54 PM Thread Starter
99 7.3 shutter/miss
thanks for the replies, truck only has 97000 miles on it, hope its not a cracked piston,lol!. truck does have noticable miss at idle, will check more with injectors. also the thing doesn't smoke all, only a puff of black smoke when i romp on it!
post #5 of 16 (permalink) Old 01-18-2009, 09:52 PM
My 2000 is doing the same exact thing. I just replaced the CPS 3 weeks ago. Maybe a bad Injector ?????
95,5 spd,ex-cab,Dually,410. Alcoa's 200,000. superchip,downpipe,4" exaust. -kitty. LUK & Brand new ZF Trans.
2000- 7.3,DRW,auto,4x4,ex-cab,Diablo prgmr,K&N,Dpipe&4" exaust, 300,000.
2003-7.3,DRW,CC,auto,4x4, Superchip prgmr, 340,000.
stretch106 is offline
post #6 of 16 (permalink) Old 01-18-2009, 11:36 PM
timbo2's Avatar
Did You Use A Grey Cps If You Did Try Putting In A Black One And See What Happens
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 232,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 93,000 on the clock
JOHN 3:16
timbo2 is offline
post #7 of 16 (permalink) Old 01-19-2009, 09:45 AM
TPford's Avatar
In short, check the Glow Plug Relay.
My '02 F350 7.3 started cutting out while accelerating. This usually happened @ 1500 - 2000rpm. The "water fuel", "glow plug", and "engine" lights would come on for one to two seconds then go off once I lifted my foot from the accelerator pedal. When the lights came on, my truck would drop from whatever rpm range it was at to roughly 700rpm, my idle speed. I ran diagnostics on a scanner, but it didn't have any codes. I started tracing wires and connections and found the problem to be a burnt Glow Plug Relay. It must have been sending a voltage spike and would reset while driving. I replaced the GPR last week and not had the problem since.
Not sure if its your problem, but thats what worked in my case.
'02 F-350 CC LB 4x4 DRW 4.10
148,*** miles, stock motor, original trans
MODS - AIS Intake, 203* w/Billet Housing,
TPford is offline
post #8 of 16 (permalink) Old 01-19-2009, 01:08 PM Thread Starter
thanks for the input, going to do cct, waiting for son inlaw to borrow buddies scanner. keep u updated on what that turns out.
post #9 of 16 (permalink) Old 01-20-2009, 10:41 AM
timbo2's Avatar
WHEN YOU RUN A FUEL CONTRIBUTION TEST AND IF IT FAILS ON THE #3 AND #8 PUT A BLACK SENSOR BACK IN IT I AM TELLING YOU I HAVE BEEN DOWN THIS ROAD BEFORE
JOHN 3:16
timbo2 is offline
post #10 of 16 (permalink) Old 01-22-2009, 01:32 PM Thread Starter
thanks for the heads up on that, that would be a quicker and easier fix than an injector!
post #11 of 16 (permalink) Old 01-22-2009, 07:47 PM
F350_6's Avatar
I haven't heard of this one, but I do know that if the wiring harness that runs over the drivers valve cover chaffes and shorts against the valve cover (or behind the 42 pin connector) it will cause the WIF, GP, & CEL lights to act funny. Can even cause stalling and no start issues. The only code was a KAM error.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #12 of 16 (permalink) Old 01-23-2009, 06:38 AM
dump_truck's Avatar
My truck is doing the same thing, what is a CCT test? I am new to Powerstrokes, have had 6.9 & 7.3 IDI's for years and this is my first Powerstroke.
99 F350 4X4 DRW LB CC 7.3 Powerstroke Centurion
92 34.5ft NUWA 4 Season 5th Wheel
dump_truck is offline
post #13 of 16 (permalink) Old 01-23-2009, 07:15 AM
F350_6's Avatar
It's a test on the engine run by a scanner.
Chris
F350_6 is offline
post #14 of 16 (permalink) Old 01-23-2009, 06:01 PM
dump_truck's Avatar
Just had a scanner run on my truck and 2 codes came up,
Code P1690 something to do with the wastegate, he was not sure what that was about.
Code P0470 EBV, told me to thake sensor off and clean it and make sure the tube was clear, that I I did, nothing changed.
Jim
post #15 of 16 (permalink) Old 01-23-2009, 06:37 PM Thread Starter
again thanks for the info, will be doing cct tomorrow and will also be checking the other things mentioned if cct checks out ok. the odd thing with my truck is it shows no codes, the check engine light or any of the lights for that matter comes on.
