99 7.3 wastegate - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 10-23-2006, 02:10 AM Thread Starter
99 7.3 wastegate
I just bought a 99 F-250 with the 7.3. The first day i had it, i took it for a road trip and put about 1,000 miles on it and it ran great. But the thing that i have noticed is that the wastegate on the turbo opens and shuts all the time, even at like 1,300rpm going slow. Or if i have it to the floor the wastegate remans closed untell 2,300rpm and then it takes off like no other. I have been told to check the turbo boost hose for carbon build up but i need some more ideas. Thanx
chevyz28 is offline
post #2 of 9 (permalink) Old 10-25-2006, 05:26 PM
fulltimer50's Avatar
My Photos: (18)
Re: 99 7.3 wastegate
How can you tell that the waste gate is opening and closing all the time?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
George
2011 F350 PSD Lariate, CC, 4x4, LB, DRW.
2013 Lifestyle LS37RESL 5th Wheel
fulltimer50 is offline
post #3 of 9 (permalink) Old 10-25-2006, 06:43 PM
KRP
Maybe you are talking EBPV rather than wastegate?
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
post #4 of 9 (permalink) Old 10-25-2006, 07:23 PM
the wastegate is in the exhaust turbine housing of the turbocharger. you can't hear the operation of the wastegate over the sound of the engine, if you could at all. it's job is to limit the amount of boost being made by dumping (wasting) exhaust drivepressure that would normally go through the turbine wheel and produce torque on the wheel.
what you are experiencing is probably a misfunctioning Exhaust Backpressure Valve (EBPV) that is causing the engine to lose power. it closes off 90% of the exhaust flow out of the turbocharger by a butterfly valve that is connected to a linkage and a control/sensor. The EBPV's purpose is to help the engine warm up to operating temperatures under a light engine load.
Hillbilly Deluxe- 2002 F-350 Crew 4x4 Auto Lariat Some stuff, 309/602 before DPtuner
TDS's youngest member
KrisMyers is offline
post #5 of 9 (permalink) Old 10-25-2006, 10:13 PM
Feedback Score: -1 reviews
So how do you know when it is set correctly or incorrectly?
I can hear mine releasing pressure as it shifts if im on it slightly.
Early 99 crew cab shorty 4X4
Custom tuned by DP Tuner
Modified H2e
Diesel Innovations - HP Crossover
Diesel Innovations - Regulated fuel return
Beans 530 Hybrids
Diesel Innovations - "Big DIIC" intercooler
Diesel Innovations - F.A.S.S. 150/180 Fuel System
Brians Truck Shop - BTS Tranny
DSALF250 is offline
post #6 of 9 (permalink) Old 10-25-2006, 10:16 PM
KRP
You know it is set correctly when you don't make more boost than you want to. I think what you are hearing is the air coming back out the intake on a shift. It's a whooshing sound correct.
KRP is offline
post #7 of 9 (permalink) Old 10-25-2006, 11:41 PM
jjeepyjohn's Avatar
Sorry this is wrong info
Not Flaming anyone .
The Whooshoing sound is you EBV closing and opening . The EBV closes and holds exhaust gases back to help the engine get up to normal operating temps quicker. If you start it and let it sit when its cold outside it will close and the idle will ramp up slowly. If you touch the brake pedal it will open and then close again shortly after. This will continue until the truck has warmed to normal operating temps.You will also hear the EBV close and open while driving if RPMs are under 1800. If it is closing and opening while driving after warm-up and over 1800 rpm then you have something wrong with either the EBV or a temp sending unit.
Hope this helps, Good luck, John
IF IT AINT SMOKIN' IT MUST BE BROKEN...
2001 F350 Island Blue,PSD,Police Interceptor Pkg,2WD,CC,LWB,AUTO,3:73,BOOST,PYRO,AND TRANS GAUGES,AFE FILTER, TS Performance ,4" Turbo Back Exhaust,
"BYE NOW"
Middle TN Email
jjeepyjohn is offline
post #8 of 9 (permalink) Old 10-26-2006, 12:25 AM
KRP
That's not the sound I'm talking about. I know what the EBPV sounds like. I think he's talking about the noise that it makes at a shift when the excess pressure needs someplace to go. It's not my truck though and I have never heard his noise so maybe you are right. It's hard to spell the noises that a truck might make. [img]/ubbthreads/images/graemlins/grin.gif[/img]
KRP is offline
post #9 of 9 (permalink) Old 10-26-2006, 08:22 PM
Nope thats not it. How do I know for sure? gutted the EBV long ago.It is bleeding off pressure when it shifts , Normal?
Modified H2e
Beans 530 Hybrids
DSALF250 is offline
