'99 7.3L PS Engine Cutting Out! HELP! - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 03-14-2010, 08:29 AM Thread Starter
Man....just found this site and I'm on cloud 9 about it. The old truck's gettin on up there in age and I'm sure I'm gonna need some help keepin her running over the next several years. On to the problem. Truck is a little hard to start in the cold. Prob a glow plug prob, not a biggie. Runs fine and smooth. Once you start driving, at around 40 to 50 mph, the engine will cut out and make a jerk (like the engine lost fuel then got it back) Jerks the vehicle pretty hard sometimes! It might do it once, it might do it 3 or 4 times within a minute. It might do it today, it might do it tomorrow. It will sometimes do it running 60 to 70 mph. Drove it 65 miles the other day and it did it about 10 times...On way back home 65 miles, never did it at all!!! I'm stumped. Any suggestions? Not trying to be cheap, but just spent a lot of $$$ on property taxes and I'm trying to solve this one at home! Thanks, David
morningstarfarm is offline
post #2 of 11 (permalink) Old 03-14-2010, 08:51 AM
Excavator's Avatar
My Photos: (11)
CAM sensor is first thing to suspect.
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #3 of 11 (permalink) Old 03-14-2010, 10:03 AM
TPford's Avatar
I am having a simialr problem that I am try to diagnose listed in a thread "Is this a CPS problem?"
Does this sound like what its doing:
While driving down the road the truck will lose power. Check Engine Light and Water Fuel Light stay on for 1-2 seconds while the WTS Light only flashes briefly. Once you take your foot off the accelerator pedal, you hear a click and power is restored to the engine?
'02 F-350 CC LB 4x4 DRW 4.10
148,*** miles, stock motor, original trans
MODS - AIS Intake, 203* w/Billet Housing,
TPford is offline
post #4 of 11 (permalink) Old 03-14-2010, 10:16 AM
Excavator's Avatar
My Photos: (11)
Does NOT sound like CPS
Next time it does this, try using cruise control to hold speed.
If OK now then I suspect the switch on the pedal
Swamps,Tony Wildman
post #5 of 11 (permalink) Old 03-14-2010, 10:25 AM Thread Starter
Yeah sounds a little like my prob. The check engine light will come on but it stays on. All other gauges read good and no other lights come on. I'm getting ready to change the oil and all filters. I know that prob won't help but it's due anyway. I can run the cruise set at about 65- 70 and it will still do it occasionaly. Could water in my fuel be a cause? Thought about running some treatment anyway through it. If it is the CAM sensor, is that something I can purchase and change myself? Can it be tested to see if it's the problem? Thanks for all the info and help!
post #6 of 11 (permalink) Old 03-14-2010, 02:22 PM
TPford's Avatar
If the check engine light comes on and stays on, it should have set a code. Get a code reader that can read for the Powerstokes to see what code was set.
TPford is offline
post #7 of 11 (permalink) Old 03-14-2010, 09:00 PM
SlickDog's Avatar
My truck did that and it was the CPS...
99 F250 SD SC 4x4 XLT Long Bed 7.3 Power Stroke
6 spd, 203 Thermostat; DIY Tymar; ZooDad; DIY Big Boost; 4" Stainless Steel MBRP turbo back exhaust; Harpoon MOD; Triple Pillar Gauges(Fuel pres, Pyro, Boost); TS 6 Position w/ SWAMP'S Tunes;
Want more?
Expect More?
DO MORE!
SlickDog is offline
post #8 of 11 (permalink) Old 03-14-2010, 10:12 PM
remedm's Avatar
I just went thru this it is the cam sensor, No question some cut out like
the one in your truck and some will kill it for a few min then start back up
and some die and never come back.
Replace the CPS all will be good.
2002 CC F-350 SB SRW 4X4 TOREADOR RED
DP-TUNER NO-START, MOD STOCK, HIGH IDLE, DRIVE THRU, 40 TOW, DECEL, 60 TOW, 60 ECON, 80 ECON, AND RACE
BTS TRANNY (NUFF SAID)
; 6.0 COOLER
DIESELSITE BOOST RELIEF VALVE, 203^ THERMOSTAT AND HOUSING, MAX A/C VALVE AND COOLANT FILTER
ATS TURBO HOUSING, FORD A.I.S., OILGUARD BY-PASS, 4" MAGNAFLOW STRAIGHT PIPE, SIDE EXIT,
NCHORNET'S CCV MOD, POR-15 OIL PAN
ISSPRO A-PILLAR PYRO/BOOST/TRANS, ISSPRO ENGINE, OIL TEMP AND VOLTS OVER MIRROR
MARINCO MOD, LED ID BAR, HEATED SIGNAL MIRRORS, LED BRAKE AND TURN SIGNAL BULBS FRONT AND REAR
RHINO BED LINER, SIRIUS RADIO
AMERICAN EAGLE WHEELS WITH 305-70-16 NITTO TERRA GRAPPLERS WITH A 2" DONAHOE LEVELING KIT
TRUCK BUILD DATE 1/8/02
BTS BUILD DATE 1/8/07 AT 41K
remedm is offline
post #9 of 11 (permalink) Old 04-22-2011, 08:42 PM
Mine is doing the same. Had the cruise set and it cut out, engine light came on and stayed on and chugged and then kept going. After doing that 3 times, it stalled and then would not start. after 3-4 minutes it started right up and engine light off. Then chugged 3 mores times and engine light stayed on.
Is CPS the CAM sensor? Is that something a backyard mechanic can do?
kenutter is offline
post #10 of 11 (permalink) Old 04-23-2011, 07:39 AM
TPford's Avatar
A year ago when this happend on my truck, I thought it might have been the CPS, but noticed that the engine would cut out when I would hit a bump in the road or hard right turns. It turned out to be an exposed wire on the wire harness that was shorting out. I found it on the main driver side valve cover wire harness near the bracket for the air intake tube. Wasn't easy to find, but a simple splice job fixed it right up.
Hope this help you.
TPford is offline
post #11 of 11 (permalink) Old 07-30-2015, 07:03 PM
HELP
is there a way to get a hold of you??
DURAMAX123 is offline
