99 F250 dies when wipers turned on - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 05-07-2006, 07:07 PM Thread Starter
Engine dies sometimes when wipers are turned on. Also sometimes when radio is turned on? when driving at highway speeds, turning wipers on sometimes causes truck to chug until wipers were turned off.
Dukowitz is offline
post #2 of 18 (permalink) Old 05-07-2006, 08:53 PM
Re: 99 F250 dies when wipers turned on
It is very difficult to diagnois like this, but I'll guess you have a charging problem...
Early '99 PSD SRW 4X4 GTP 38R, DI intercooler, Stealth SRP1, DS regulated return, Stock injectors, Ford AIS intake, DP tuner, 203 t-stat, Gauges, coolant filter, Amsoil bypass.
ATS trans and converter, 31 row cooler, external filter, 4.10 ARB Lockers, Traction Bars, 33" Toyo MT, tons of other stuff.
2005 Harley front end, Trail Ready, Daja Design, Vision X
project20v is offline
post #3 of 18 (permalink) Old 05-16-2006, 09:53 PM Thread Starter
Charging system fine. Ford Dealer has no clue. small time shop
suggested the multifunction switch under steering column? (stated
fords are notorious for them going bad, and has even heard of starter
engaging when radio is turned on).
Dukowitz is offline
post #4 of 18 (permalink) Old 05-17-2006, 01:39 AM
JimTJr's Avatar
My Photos: (20)
Have you owned this truck long? Almost sounds like it has been submerged before, This will cause all KINDS Of electrical problems... WOW, talk about GREMLINS!!! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
I dont have a clue as to where to start looking. But if you got ahold of a good wire diagram and look to find some common area from radio/w/s wipers to the engine operating system, replace that common item? I have no idea what your small time shop is talking about with a multifuntion switch on the steering column? Cant be too common a failure, I have never read about it on here in almost 5 years as a member. AND TONS of time on here! LOL
I think I would check the fuse block? Look on the back for corrosion, Also look at all wireing looms for any melted wires, Maybe one or two got pretty hot and melted together? Your starter engages when you turn the radio on? [img]/ubbthreads/images/graemlins/eek.gif[/img] Good luck and let US know if you find something ok?
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #5 of 18 (permalink) Old 05-17-2006, 07:03 AM
Rickie's Avatar
At first I thought it might possibly be something related to the recall for the wiper motors. Wiper motors catching on fire, etc. A faulty motor could cause some kinds of electrical gremlins by dragging down the system voltage on some circuits. Then I saw you had more electrical issues.
Check all the ground connections. Problems with accessories coulld be related to the engine controls. One common item the circuits share is the ground connections.
Also check the connections from the batteries, (make sure they are clean) and the alternator to the fuse panels. Condition of fuse panels, such as accumulated dirt in the outside unit could be a factor.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
post #6 of 18 (permalink) Old 05-18-2006, 05:38 PM
Sounds like it might be the "fubar" part. [img]/ubbthreads/images/graemlins/wink.gif[/img]
2001 Silver F-250 7.3L 4WD, extended cab, 130k miles, BF Goodrich A/T 285/75; BTS auto tranny w/6.0 cooler, AIS severe duty intake and filter w/Zoodad mod, 6 position chip from BTS, 4" turbo-back exhaust, Magnaflow muffler w/5" tip, Speedliner sprayed-in liner, Monroe Reflex shocks, Isspro pillar gauges
sparvin is offline
post #7 of 18 (permalink) Old 05-22-2006, 02:37 PM
I would try to isolate the problem first. First, prove that it's not related to the wipers and/or the radio. With the motor running, connect a 12-volt bulb across the battery terminals. Did that make the motor die? Try a bigger bulb. Did the motor die? If either bulb made it die, then it is probably related to how much current is being drawn from the battery. Now, try attaching a battery charger to the battery with the motor running. Do the same test with the bulb. Did the symptoms change? If having the battery charger prevented the motor from dying, then the alternator/battery probably isn't providing enough current to keep the motor running. By having the extra 10 amps or so that the battery charger added, the bulb didn't bring the motor to a point of losing shutting down. Try the wiper/radio test with the battery charger connected. Another test to do is to fully charge your battery for a couple of days and see if your symptoms still occur. If the symptoms are independent of the state of the battery and alternator, then it might be wiring somewhere.
Not all car shops do scientific analysis when it comes to diagnosing these problems. Replacing a part to see if the problem goes away is what they typically do. However, some intermittent problems merely become less intermittent that sometimes, it appears that the problem went away.
2001 Ford F-250
7.3L Powerstroke
Crew cab, standard bed
All stock
1991 Motorhome
160HP Cummins 12-valve 5.9L
*** LOST CAM at 26,581 miles !!! ***
Cummins didn't want to pay for repair
Cost me $10k for a remanufactured motor
alpinewhite is offline
post #8 of 18 (permalink) Old 05-22-2006, 07:20 PM
I have seen the same problem on a 96 PSD. There was some electrical interference from the wiper motor that interfered with the engine electrical. I replaced the wiper motor and haven't had a problem since.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #9 of 18 (permalink) Old 05-22-2006, 07:55 PM
Tom S's Avatar
My Photos: (20)
Seems like I have seen this posted before. Do you have any electronic power adders? You may want to try searching on this in archives.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood,
PMF RSK V and B code springs
Tom S is offline
post #10 of 18 (permalink) Old 05-22-2006, 10:12 PM
My Photos: (18)
Any chance you have a windshield leak and it is getting on your GEM module? (located under the radio or thereabouts I believe but could be wrong, sorry). A few folks with cracked windshield report leaks on this module also.
garyT
2002 250SD,4x4,XLT crew,6Spd.,4"ATS exhaust,ATS housing,SP Intake,,Edge Evo, Southbend CLutch CON OFE,BD short shifter, ITP Boost Regulator, Warn Preminm Manual Hubs.
DYNO: 325 hp 728 ft lbs
garyt is offline
post #11 of 18 (permalink) Old 05-23-2006, 02:26 AM
It is a gem module issue. I had a similar problem with my '99. for example, if I pressed the brakes my windshield wipers turned on. The worst was the power door locks would spontaneously activate, locking me out of the vehicle. There were other symptoms as well. The Ford dealership had no clue. It took three service calls in two days to resolve the issue.
1999 F-350 SRW, 4x4, 6-Speed, Superchips Microtuner, Warn Hubs, South Bend Clutch, aFe Stage 2 intake
2009 F-350 SRW, 4x4, Stock for now
Hypnos is offline
post #12 of 18 (permalink) Old 05-24-2006, 09:33 AM
diesel dave 99's Avatar
The last one I had do this It was the ground wire that is just to the right, above the Master cyl on the fire wall. it was a bad Ground. Good luck this is the ground that grounds the PCM.
08 F-350 Crew Cab Dually 4X4 Lariat 6.4 4:10 gears. [email]
diesel dave 99 is offline
post #13 of 18 (permalink) Old 09-15-2006, 10:43 AM Thread Starter
Thanks for the suggestions, although they have not lead to the repair. I have changed the multifunction switch & the very expensive GEM. I will not order the wiper motor & check out the ground wire. I also had the front end go out again. (once at 35K & now at 55K). If you ever have to do the same. order the Dyna free spin kit from offroadunlimited. (half the price as the dealer, & stronger).
Dukowitz is offline
post #14 of 18 (permalink) Old 08-12-2014, 05:53 PM
wipers shutting down engine
I am have having this same problem with my 1999 7.3 F250 super duty. Using the wipers will shut down the engine. It happens rain or shine. Replaced the cps with a ford cps. Still happening. Replace the wiper motor, still happening. Re wired the wiper motor, still happening. I had a mechanic spend two days going over all the wiring ect. He has no idea. If I am giving the truck fuel it just hiccups and the check engine light comes on. If I am at a stop engine shuts off. Please help with any advice!!!! I have tried everything and have reached a point I may have to sell.
Oregon1 is offline
post #15 of 18 (permalink) Old 08-12-2014, 07:41 PM
klhansen's Avatar
My Photos: (180)
If the check engine light comes on, then there will be a code stored that should point you in the right direction. Getting is scanned is the FIRST thing you should do.
Even though you've changed the CPS, there might be a spot in the harness that's chafed and shorting out intermittently.
Again, the codes will point you toward the solution.
Welcome to TheDieselStop
), AIS,
regulated return,
klhansen is offline
