99 F250 sd front wheel bearing replacement ??? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-16-2006, 09:44 PM Thread Starter
I believe the needle bearings in the pass. side front axle are shot. Is there agood picture of the outer axle assy for the super duty trucks?
Any special tools needed??? Hub wrench?? Did a search and was hoping for a write up on this subject.
Thank you in advance!!!
rb69 is offline
post #2 of 5 (permalink) Old 12-17-2006, 04:36 AM
klhansen's Avatar
My Photos: (180)
Re: 99 F250 sd front wheel bearing replacement ???
HERE is an excellent article on ball joint replacement, which goes just a bit deeper than you need to go.
Standard hand tools are all that's needed.
), AIS,
regulated return,
klhansen is offline
post #3 of 5 (permalink) Old 12-17-2006, 07:47 AM
SmokeyWren's Avatar
My Photos: (45)
Assuming your rig is a 4x4, then you have a Dana front axle and you cannot replace or even pack the front wheel bearings. The only fix is to replace the ball joints per that article Kevin linked to.
Kevin stated "Standard hand tools are all that's needed" but he forgot to mention that you'll need to borrow/rent a ball joint removal tool. Per the article: "Place knuckle in vice and use a ball joint removal kit to drive out lower and upper ball joints. I borrowed one of these kits from AutoZone."
But if you have a 4x2, then you have a normal Ford "twin I-Beam " front axle, and the front wheel bearings can - and should be - packed every 30k miles. All you need is new grease seals and some wheel-bearing grease. And a wheel bearing packing tool is nice to have, even if you know how to do the nasty job of properly packing a wheel bearing by hand. [img]/ubbthreads/images/graemlins/crazy.gif[/img] And if necessary you could replace a front wheel bearing, but that's pretty rare in a 4x2.
SmokeyWren is offline
post #4 of 5 (permalink) Old 12-17-2006, 05:01 PM
Cool_Canuck's Avatar
My Photos: (12)
Smokey is rambling again. It part of the aging process. [img]/ubbthreads/images/graemlins/smile.gif[/img] You don't need to rent a ball joint press unless you decide to do ball joints. Kevin just pointed to that article as it deals with the bearings as well.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
post #5 of 5 (permalink) Old 12-17-2006, 06:46 PM Thread Starter
Thanks to all who posted... The link helped alot.
What I found was that the needle bearing was shot. I replaced the bearing and that fixed it. I need to replace the outer seal in the hub, but for now as the weather is starting to change here in Iowa the needle is all it will get... Ball joint where replaced earlier this fall..
Thanks for the link and the awsome site!!!!
rb69 is offline
