'99 f350 drw lariat CC 4x4 7.3psd... 9800.00???? - Diesel Forum - TheDieselStop.com
Old 05-23-2006, 05:13 PM   #1 (permalink)
im going to big H auto auction later today, my friend is a dealer, and he found a f350 dually up there for sale, theyre asking 11,000.00 and it has around 230,000.00 miles, the body is kinda rough, w/ dings/and scratches. but the leather inside is decent condition. its a manual tranny, and sounds like it runs good. there no excess smoke, and no fluids dripping, ac works good. i will more than likely get this truck for around 9000.00-10,000.00 cash.
the problem is, the 4x4 light on the gauge cluster is illuminated. i tested the 4x4 in the lot, and seemed to be in working order. i didnt want to drive too much in 4wd cause it was gripping pretty good, when trying to turn.
im wandering what should i lookd for, problem wise? should i look for a certain color fluid in the radiator, etc? the only inspection i can do is very minimal, i cannot bring tools and start ripping it down.
this is a dealer auction where all the cars around the houston and surrounding areas run through.
thanks for any input
*edit*
the truck looks as though its obviously been worked.
userName is offline
Old 05-23-2006, 05:38 PM   #2 (permalink)
NCHornet's Avatar
Re: '99 f350 drw lariat CC 4x4 7.3psd... 9800.00????
with that many miles it all comes down to maintenance. It can be at the end of it's like or still have another 230K left in her. Sounds by the description it has been worked well, this doesn't mean it has to been well maintained but it does mean it hasn't been babied. If you can pull the intake tube a feel the turbo wheel for play. If it has a K&N drop in filter run away, if it had a chip or tuner installed with no guages I would run away twice as fast.
Buyer beware at these auctions
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 05-23-2006, 05:42 PM   #3 (permalink)
ill see if i can get the intake boot off w/o them harrassing me. on another note, the truck is all stock. ill have to check for the k&n filter though...
trey
2003 f250 CC SB 7.3PSD FX4 ---- completely stock (dads truck... lol)
'95 f350 4x4 CC 7.3psd 5spd. (in the making)
userName is offline
Old 05-23-2006, 05:46 PM   #4 (permalink)
is there a certain amount of play the impeller should not exceed? or is it not supposed to have any play whatsoever?
userName is offline
Old 05-23-2006, 05:46 PM   #5 (permalink)
Too close to flooded areas from the hurricanes for me to want anything going through a Houston auction. Look carefully for crawdads and mud where it ain't supposed to be [img]/ubbthreads/images/graemlins/smirk.gif[/img]
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline
Old 05-23-2006, 05:49 PM   #6 (permalink)
i have a flood gauruntee at the auction, so im not worried about that.
userName is offline
Old 05-24-2006, 10:03 AM   #7 (permalink)
Did you buy it???
Used goats for rent
twobit is offline
