99 PSD ZF6 Grinds going into 3rd? Only 95k on it - Diesel Forum - TheDieselStop.com
Old 06-01-2011, 09:45 AM   #1 (permalink)
Angry 99 PSD ZF6 Grinds going into 3rd? Only 95k on it
My 99 PSD w/ ZF6 is grinding going into 3rd. No problems going into any other gear, so I have been skipping from 2-4 whenever I can. Could this be fluid level related or is it something else? Thanks
schmegly7 is offline   Reply With Quote
Old 06-01-2011, 03:44 PM   #2 (permalink)
RT
RT's Avatar
Mechanically, it would be a stuck synchronizer. Whether you could free it up with a oil change is a crap shoot. Not likely, but weirder things have happened.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is online now   Reply With Quote
Old 06-01-2011, 04:17 PM   #3 (permalink)
Thanks for the reply. So I am guessing that I will need to have the tranny torn down and replace that synchro along with anything else that looks bad?
Old 06-01-2011, 04:21 PM   #4 (permalink)
I thought that the ZF6's had synchros for two gears tied together. 1-2, 3-4, and 5-6. Are they individual for every gear?
Old 06-01-2011, 05:32 PM   #5 (permalink)
klhansen's Avatar
My Photos: (175)
The synchros are paired L-R (yes, reverse is synchronized), 1-2, 3-4, and OD. The parts list, just lists the synchronizer assemlies. You could probably repair one side of the pair if you could find the individual parts, but most just replace all the synchros once the tranny is opened up. I was quoted a price of $2000 locally, just to tear down my ZF6 when I had problems with coolant in the oil. I wound up getting a rebuilt tranny installed, with Ford kicking in some money since it was JUST out of the 36,000 mi warranty.
In it's last throes, I was running a ZF3
I'd try a fluid change first and see what happens. A synthetic ATF might be the ticket, if you want to spend the $40 or so it would cost for 6 qts.
Or you might try one of Redline's products that might be a little thicker than ATF. (This suggestion is untried by me, so take it with a grain of salt, however, the newer ZF6's behind the 6.0L & 6.4L's specify gear oil instead of ATF.)
Hard or no-start? Check Here
Old 06-02-2011, 11:38 AM   #6 (permalink)
TransBrain's Avatar
Synchro rings have worn out.
TransBrain is offline   Reply With Quote
Old 03-14-2012, 12:10 PM   #7 (permalink)
So what was the damage did you do it yourself? If so how big of a job was it?
1996 SC 4X4,170K AT, Cat coolant, 12K Warn, Bumper Heater plugs, 2 10" Subs under the back seat.
mcintoshjr is offline   Reply With Quote
Old 03-14-2012, 01:07 PM   #8 (permalink)
You need Synchronizers. Pretty big job. Have to also replace some other parts. Mine was done at 55,000. I bought the truck with 52,000 (in 2002) and it was grinding occasionallly. Actually did it on the test drive. The saleman told me there was no problem. Within 3000 miles it started jumping out of 3rd and grinding on every shift.
I live in a small town and took it back. The owner ate the cost of a rebuild, because he didn't want "bad press" and I had pointed out on the test drive that there was a problem.
There were more than one ZF6 offered. In 2000 they came out with a higher HP and torque rated ZF6. I would go to a local "big truck" dealer and try to buy a later higher rated ZF reman.
Ford ZF S650 6 speed Rebuild Kit Manual Transmissions - Drivetrain.com
It looks like a reman from the same company is about $2500.00 plus core.
Chris
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2009 Chevrolet Traverse(wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
2010 Kawasaki TransMule Diesel
firefighter9208 is offline   Reply With Quote
Old 03-15-2012, 10:03 AM   #9 (permalink)
My damage was caused by a hole in the radiator which allowed coolant into the tranny fluid. Entire tranny was rusted inside, so I had it all rebuilt locally. New clutch while we were in there and a new radiator of course. I know that this fixed the problem. Looking back the only way I would have known is if I had checked the tranny fluid more often. It never leaked on the driveway or in the garage. I could have tried draining in and puting a synthetic fluid in or even pouring in 6 quarts of marvel to see if it would loosen up, but I bit the bullet and just had it rebuilt.
Old 03-15-2012, 08:51 PM   #10 (permalink)
klhansen's Avatar
My Photos: (175)
Really?!!
That's exactly what happened to my original tranny.
The OTW cooler broke, allowing coolant into the tranny and ATF in the coolant. It took out the synchros in short order, and finally puked pink stuff out the radiator cap. Ford dealer replaced it with a rebuilt (and a new radiator). It was at 40k miles (just out of warranty) but Ford chipped in half the cost as they'd never seen that happen before, and I had good maintenance records.
