99 zf 6 speed disassembly - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-20-2007, 06:46 PM Thread Starter
does anyone know where i can get the disassembly procedure or a break down of the components in the zf 6 speed manual particularly the shift bar housing or related part
2000 ford f-350 cc dually 4x4 auto- rcd 2.5" front lift, eagle alloy rims, mbrp 4" exhaust turbo back, 3 gauge pillar boost, pyro, tranny, dp tuner f5 6 pos chip, billstein shocks, mag hytech trans pan, different fuel pressure spring, dual rancho steering stabilizer, tn 1.00, high flow outlet ceramic coated, 6.0 spearco cooler, flexalight fans, fass 150, IH plug, 203* thermostat, billet therm. housing, non ebv pedastel
best time yet, 15.44
trx300exnj is offline
post #2 of 7 (permalink) Old 11-20-2007, 06:56 PM
Re: 99 zf 6 speed disassembly
I know a guy locally who does tons of those trannys. There are a lot of things that need to be inspected, lots of little tricks and some special pullers required to properly disassemble one of these units. A word to the wise, unless your trying to patch it, leave it up to the pros to fix. Also I know the shafts get bent due to other bad parts making it hard to shift.
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip]
SMOKESKULL is offline
post #3 of 7 (permalink) Old 11-20-2007, 07:07 PM Thread Starter
lol i am a "pro" im a diesel tech and work for cat i just need the service manual on the trans so i can do a little research buddy of mine said 6th gear wont engage and gets stuck wanted to see if that trans used a shift bar housing utilizing detent balls and springs and the type of syncros used thanks for ur 2 cents though
post #4 of 7 (permalink) Old 11-20-2007, 07:15 PM
What smokeskull said.
Once you start tearing into it be sure to save all the parts so you end up with a fully creditable core.
early 99 F350 4x4
DieselDeaf is offline
post #5 of 7 (permalink) Old 11-20-2007, 07:20 PM
Rich_Kimball's Avatar
Try this link to see if it helps you:
ZF S6-650 North America
It has an exploded view and parts list.
Happy trails,
Rich Kimball
Went to new owner on 12/12/09 (I will miss her)
2000 F350 XLT CC LB SRW 6spd 4x4 Toreador Red
'08 Center Console,Ranch Hand Grill Guard, SBC ConO clutch,DP Tuner (60T,80E,120R),Gauges,Ford AIS,Walker BTM,AIH delete,HPX Oil Crossover, Wicked Wheel,TurboMaster WG Contoller,Riley BRV+,Riley Boost Boots,EBPV Gut w/mod. pedestal,IH Bellowed UpPipes,Final Charge ELC coolant w/heater bypass,Riley Coolant Filter,Ford AIC,Centramatic Wheel Balancers,115gal Aux tank,Firestone airbags w/cab control. Oilguard Bypass Filtration,DFA 'Cross Connect' Fuel Lines
Rich_Kimball is offline
post #6 of 7 (permalink) Old 11-20-2007, 07:37 PM Thread Starter
thanks exactly what i needed
post #7 of 7 (permalink) Old 11-21-2007, 02:36 AM
He told me once that he went tru 6 cores before he found 1 that was rebuildable. Sometimes theres so much wrong there just junk inside.
