ABS light is on - Diesel Forum - TheDieselStop.com
Old 11-24-2009, 09:32 PM   #1 (permalink)
ABS light is on
I have a 1999 powerstroke, I was driving down the road and the ABS light came on the speedometer quit working and the overdrive light started flashing. The truck still seam to run fine, came home and check all the fuses and they were fine any ideas?
fishknot is offline
Old 11-25-2009, 06:17 AM   #2 (permalink)
CPUNeck's Avatar
My Photos: (13)
Vehicle Speed Sensor (VSS) located a top the rear differential. Tells the computer how fast your going, and the ABS whether a wheel is locked. Easy fix, buy replacement, 1/4" 10mm socket with small extension and your done.
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
SVO Conversion Updated SVO stuff
CPUNeck is offline
