ABS light -- changed rear speed sensor, but light still on! - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-04-2006, 08:21 PM Thread Starter
My ABS light has been on for several months. I finally got around to replacing the rear speed sensor, but the light remains on. I checked the new sensor before installing, and it came in around 1925 in resistance, so I don't think it's the replacement sensor.
The light is on while waiting for the "wait to start" light to go out. Thereafter, it goes off for just a fraction of a second after starting, but then comes right back on.
Any ideas? Thanks!
2000 Excursion 7.3 Powerstroke 4x4
Triggerfish is offline
post #2 of 7 (permalink) Old 12-04-2006, 08:26 PM
calabrese19's Avatar
Re: ABS light -- changed rear speed sensor, but light still on!
have you pulled any codes?
Tony
06 F350 Fx4 PSD
ARP HeadStuds - AEM BruteForce intake - MBRP 4" turboback-EGR delete - Ford blue fuel spring - 6.4 banjos - diy ccv
Viper 5900 remote start/alarm w/ one mile range - Pioneer D3 nav - 2500 watt power inverter - Harley headlights - Recon smoked cab lights - ebay 2.5" axle mounted leveling kit
DieselSite coolant filter- added at 39k
8ft WESTERN Pro-Plus w/ back drag blade
6000k slim ballast hi/lo H13 headlights and H10 fog HID kits from ddmtuning.com
to be done mods.. Innovative SCT X3, Edge Insight CTS w/ egt, oil bypass
88 mustang hatch- 347 stroker - for the strip
88 mustang vert- 4.6 DOHC gt-45 turbo - street car
calabrese19 is offline
post #3 of 7 (permalink) Old 12-04-2006, 08:31 PM
Check your front ABS sensors at the hubs, had the same thing happen and it was hub bearings gone and eat the tip of the sensor off.
2000 F250SC,SWB,Lariet,7.3,305x16SUPERCOMPS,TrailerTow,
Clearance Lights,BTS Trans(Complete w/T-shirt,Decal,BTS #36 Fuel Filter Wrench), BTS/Cale 3 stage 60t,80t,80dd chip,6.0 cooler,Autometer Gauges Trans.Temp,Boost,Pyro,High Idle Mod,(((XM)))
Joel2000 is offline
post #4 of 7 (permalink) Old 12-04-2006, 08:52 PM
stateboy776's Avatar
First check your codes.
I had to replace the ABS computer. It just quit working one day out of the blue. Its a piece of cake to change but it will set you back about $500.00. [img]/ubbthreads/images/graemlins/sick.gif[/img]
PMT1 PCM,
Short Box Lariat,Auto,4X4,F350
Black with Tan Leather,Straight Piped with full gauges.
BUILD DATE 08/00
stateboy776 is offline
post #5 of 7 (permalink) Old 12-04-2006, 09:06 PM
I 'd be takin out the bulb.....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #6 of 7 (permalink) Old 12-04-2006, 10:55 PM
[/ QUOTE ] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
You could always stick in that spare bucket of sand you keep around. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Just Kidding, but I couldn't resist.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
post #7 of 7 (permalink) Old 12-09-2006, 10:14 PM
May sound weird but mine has come on with differing, low rear tire pressures! I don't know if it's a coincidence or not but it goes out promptly after the offending tire is filled. Two seperate times it was a nice feature because I had a leak from a nail. My pressure dropped to about 20psi due to the leak.
Y2K F350 XL PSD SuperCab 4X4 MAN HUBS 6spd MAN SB SRW Trailer Tow 9900# Edge Evolution
Cris is offline
