AC stops working - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 07-14-2011, 12:24 PM Thread Starter
djlehmann's Avatar
AC stops working
works fine for awhile and then just stops...turn off and on couple times and starts again..is that a sensor or relay? on the 2002.
2003 F250 Lariat 4X2 Crew Cab 3:73LS Auto
djlehmann is offline
post #2 of 10 (permalink) Old 07-14-2011, 01:42 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Possibly, sounds more like the clutch though.
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #3 of 10 (permalink) Old 07-14-2011, 02:09 PM
RT
RT's Avatar
And as always, don't forget to check your air gap... airgap.pdf
RT is offline
post #4 of 10 (permalink) Old 07-15-2011, 12:03 AM
nctuso's Avatar
check the plug to the compressor too. mine got hot somehow and doesn't make a good connection. it would intermitently go off and on
2001 7.3L F-350
4 door long bed
-210,000 miles on the truck
-2nd motor with ~115k miles on it
4" Flo~Pro Turbo Back Exhaust, 6637 with Pete's Pre-Filter, Superchips 1700 Programmer-60hp Setting, Glow Shift EGT-Trans Temp-Boost gauges, trans triaccumulaor spring &valve kit, 285 Goodyear Duratrac Tires, Standadyne used most fill ups, 15-40W Valvoline every 3-4k
nctuso is offline
post #5 of 10 (permalink) Old 07-19-2011, 05:13 PM
mine quits working after about 20 miles down the road. If you let of the accelerator it starts blowing cold again. It usually begins around 70 mph to stop blowing cold. A guy at O'reilly's auto parts seems to think it's a screen clogged in the line that catches trash in the refrigerant line. Anytime I get back down to 45 mph or less it works great! Any help out there?
RUPLUMBING is offline
post #6 of 10 (permalink) Old 07-19-2011, 05:42 PM
My 02 F-250 was doing the same thing. When it was real hot it would quit cooling. Removed the outer compresser clutch plate, removed the small spacer washer (which closed the air gap) & put the plate back on. Works great.
Shugar is offline
post #7 of 10 (permalink) Old 07-19-2011, 06:08 PM
I read that same thing today, thanks. But why in the world did that "fix" it? I've got 166,000 miles and it just started, is the clutch going or something?
post #8 of 10 (permalink) Old 07-19-2011, 06:13 PM
RT
RT's Avatar
What happens is the clutch end plate wears to the point where the electromagnet can no longer maintain engagement reliably. Decreasing the gap reduces the force required to stay engaged. You can buy a new end plate if yours looks too chewed up, but just correcting the gap works and will buy you some extra time.
RT is offline
post #9 of 10 (permalink) Old 07-19-2011, 06:24 PM
Gotcha! Thanks!
post #10 of 10 (permalink) Old 07-23-2011, 12:50 PM
Last year, it was the plug and pressure switch. Changed those out, and it worked fine till a couple weeks ago. Checked the gap...it was .055, took out the washer, new gap is .014, and all is good...no cutting out.
2003 F-350 SD, 7.3 PSD, Auto, CC, LB, SRW, FX4, 4.10:1 Genuine Gear Ring and Pinions, Detroit Truetrac Differentials F&R, FabTech Ladder Bars, SuperChips 1705, EBPV delete, IH Up-pipes, Magnaflow 4" Exhaust, Ford AIS Air Cleaner, ISSPRO Boost, Trans, and EGT Guages, Kenwood DNX6160 with Nav & XM, Ford AIC, Brite Box, 203* T-Stat and Billet Housing, Tru-Cool 4739 MAX, ProComp StageII 4" Lift on Eagle 589's with 35x12.50x16.5 BFG AT KO's, Centramatics, WeatherGuard Toolbox, Rhino Liner, B&W Turnover w/Companion 5th Wheel Hitch & Firestone Ride Rite Airbags, PacBrake PRXB.
2009 Forest River XLR 3712SA ToyHauler
capt205 is offline
