Accelerator pedal does nothing at times - Diesel Forum - TheDieselStop.com
Old 09-07-2009, 07:49 PM   #1 (permalink)
2000 F350 125K. Starts and runs fine most of the time. But lately every now and then when I push the accelerator pedal nothing happens. Keep pushing off and on and it suddenly accelerates and runs normal again. Can't tell if I'm getting a "service engine" light because it's been on for at least 80K. Any ideas?
Y2K F350 SRW CC SWB PSD Auto 3 pillar gauges PP111 36ft Alfa Ideal 5er
rminor is offline
Old 09-07-2009, 08:17 PM   #2 (permalink)
woodnthings8's Avatar
Your throttle pedal has two switches built into it. The throttle switch is bad. It sends a voltage signal to the pcm depending on pedal position, maybe try checking the connectors for being loose, otherwise you will need to replace it.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 09-08-2009, 04:43 PM   #3 (permalink)
I just checked and the part F81Z9F836AB is back ordered just about everywhere. Must have had a lot of them going bad. I'm supposed to drive it 500 miles this weekend so I guess I'll have to take a chance. I unplugged and plugged the connectors several times so I'll see if that did anything. Thanks for the info.
rminor is offline
