Air Bag code 27--What does it mean? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-17-2007, 09:54 PM Thread Starter
CPUNeck's Avatar
My Photos: (13)
Son plugged in his DS the other day, and now my Air bag light is on [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
CPUNeck is offline
post #2 of 7 (permalink) Old 02-17-2007, 09:59 PM
klhansen's Avatar
My Photos: (180)
Re: Air Bag code 27--What does it mean?
Here ya go. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Maybe he smoked a fuse.
LFC 27/DTC B1884 Passenger Air Bag Deactivation (PAD) Switch Warning Lamp Inoperative
Normal Operation
The air bag electronic crash sensor (ECS) module has the ability to deactivate the passenger air bag under certain conditions. When the passenger air bag is deactivated, the passenger air bag deactivation (PAD) switch warning lamp will be illuminated.
The ECS monitors the PAD switch warning lamp for open or short to ground conditions. If the ECS detects an open or short to ground condition on the PAD switch warning lamp circuit, it will store a diagnostic trouble code (DTC) B1884 in memory and flash a lamp fault code (LFC) 27 (or higher priority code if one exists) on the air bag indicator.
Possible Causes
An open or short to ground on Circuit 1113 (Y/LG).
A damaged or burned out PAD indicator.
A damaged or inoperative PAD switch.
A damaged or inoperative ECS module.
A blown PAD switch I/P Fuse 22 (7.5A).
), AIS,
regulated return,
klhansen is offline
post #3 of 7 (permalink) Old 02-17-2007, 10:15 PM Thread Starter
CPUNeck's Avatar
My Photos: (13)
U da Man [img]/ubbthreads/images/graemlins/laugh.gif[/img], thanks for the quick response... I did notice the passenger light was not on any more, but I thought is was due to the general malfunction of the system [img]/ubbthreads/images/graemlins/shrug.gif[/img]
CPUNeck is offline
post #4 of 7 (permalink) Old 02-17-2007, 10:54 PM
Go to radio shack and get a 1/8" LED. Solder it in place of the blown bulb in the switch and the code will go away.
Alan -
2001 F-250 4X4 Ext-Cab 3.73
Tools: AutoEnginuity; Homemade UVC breakout Pigtail
Fluids: Rotella ELC; DELO 400 15W40; Royal Purple MAX ATF & MAX Gear
amiller93 is offline
post #5 of 7 (permalink) Old 02-18-2007, 08:44 AM Thread Starter
CPUNeck's Avatar
My Photos: (13)
Cool, better than stock! Thanks [img]/ubbthreads/images/graemlins/smokin.gif[/img]
CPUNeck is offline
post #6 of 7 (permalink) Old 02-19-2007, 08:26 AM
I used a spare dash light bulb I had laying around to fix mine in my F250 when it went out. I actually had both the one in the dash and the one in the passenger module go out at the same time. So I got the annoying Beep from under the dash board.
2002 Excursion 6" lift, 16x10 mickey thompson classics, 315/75/16 BFG mud terrains. 4" turboback exhaust, ford AIS intake with fender sleeve, boost, pyro, tranny temp gauge. DP tunes on an SCT 40 tow, 80 Econo. 131,000 miles
DEZEL73 is offline
post #7 of 7 (permalink) Old 09-25-2010, 08:55 PM
my fix
I bought multiple LED's and one pack of 12v mini bulb from Radio Shack. The LED bulbs burned out and/or didn't clear the airbag light. The mini 12v lights worked great part # 272-1099 and there is three per pack. Mine is fixed good luck on yours.
al8ball69 is offline
