Alt. Bearings - Diesel Forum - TheDieselStop.com
Old 07-04-2009, 07:00 PM   #1 (permalink)
Alt. Bearings
Can And If You Can How Do You Greese The Bearings On The Altanator.are What?
2002 F350 7.3 deisel
dieselnew is offline
Old 07-04-2009, 07:05 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
Nope, alternator bearings are typically "lubricated for life". Meaning their life, not yours.
If they're making noise, they need to be replaced, usually with a rebuilt alternator as the easiest path.
Hard or no-start? Check Here
klhansen is offline
