Just to conclude since a majority of the threads I have been reading do not come back and confirm the problem they had after posting their questions and troubleshooting .
My vacuum problem ended up being the knuckle seal on the hub I replaced just over a year ago..... After changing my shocks and steering stabilizer, I tackled the dreaded knuckle seal. After reading some nightmare type stories of ruining seals with the "homemade tool" made from galvanized pipe, I made sure my flange tool was shaved down so it went down into the seal and rode on the meat of the metal as mentioned here. After greasing the seal, and cleaning up the axle area the seal was to slide onto, it went on like clockwork with just a couple of good solid whacks on the homemade tool with a hammer..
The rest of it went just as smooth. 3 hours total including the shock and steering stabilizer installs. I would caution one to make sure you have the rotor shield on correctly before you tighten all the bolts down......don't ask me how I know......
Took her for a drive with the new "ride" and shifted her into 4x4HI.....She shifted in and out just fine and my AC stayed in the vents......
Knuckle Seal Part Napa Part # 28600 bought locally .....SKS brand $31.50..(Ford wanted $59)
Yellow o-ring $4.75...from Ford house.
Thank you gentlemen for all your help.....no telling how much money this place saved me this weekend......plus it gave me a much needed refresher on the hub bearings in case my other one goes out.
