I had a similar issue. I replaced all of the components that you described and I still had, what I thought, was a slight oil leak. It turns out that my fuel line that runs along the passenger side cylinder head (from the fuel bowl to the back of the passenger side head) had a hole in it. The hole was due to one of the rubber coated clamps that is used to hold the line. The rubber had worn off and rubbed a hole in my fuel line. The fuel was seeping through the weak spot in the line, pooling in the intake area, and eventually leaking onto the ground. By the time it hit the ground it looked just like oil. Good luck!
2003 F250 7.3 CC SWB 4X4 - Stock except for:
-Switched 10K mod that I never use
-TQ lock up switch that I never use
-305/70/16 Bridgestone Dueler A/T
