Any pointers for fixing turbo pedestal oil leak - Diesel Forum - TheDieselStop.com
Old 02-02-2010, 08:08 AM   #1 (permalink)
Looks like an awkward area to work on, any pointers on this job, or links to how to do it? Any special tools needed? How many o-rings are there that should be changed, and do you have a good source for the o-rings?
'99 F250 (built 2/98) 7.3, 6-speed manual, 3.73s, zoodad mod, Ford Severe-duty air filter, Dieselsite coolant filter and 203* t-stat, bypass oil filter, Warn hubs, '08 Diff cover, EBPV disconnect, Isspro gauges, 4" mbrp straight pipe, all new intake/engine boots from Dieselsite, DP F6, leveling kit, ccv.
2000 F250 4x4 XLT Lariat (for sale)
Lithgow is offline   Reply With Quote
Old 02-02-2010, 09:12 AM   #2 (permalink)
Bill1013's Avatar
http://www.forddoctorsdts.com/public...3HPOPGuide.pdf You can try to bring this up, for some reason I can't seem to boot it up, but it's the place to go for HPOP repair info. This TDS site will block some web sites sometimes. Could be they are having trouble on the web page, it's a PDF file.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07 Gave this one to my Grandson, only 7K miles on the engine.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline   Reply With Quote
Old 02-02-2010, 10:34 AM   #3 (permalink)
Thanks, lots of good info there! It didn't really have anything on the turbo pedestal o-rings though. It was for the HPOP. I will save it for future reference though.
Old 02-02-2010, 10:51 AM   #4 (permalink)
tbpower's Avatar
You will need to pull the turbo to fix the leak. http://www.dieselorings.com/docs/Pow...structions.pdf. I also gutted the ebpv flap while I was doing it. Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ. I'll see if I can find the instructions for deletting the actuator rod if you are interested.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline   Reply With Quote
Old 02-02-2010, 11:06 AM   #5 (permalink)
tbpower's Avatar
Here is the link to getting rid of the rod. I used a 1/4 npt plug and tap and used locktite. Turbo :: Gut and Plug video by MazdaMartinb4k - Photobucket
Also, you can get all the o rings from dieselorings.com. He also has a set for the turbo. Also this would be a good time to install a wicked wheel which helps to prevent turbo surge.
Old 02-02-2010, 11:14 AM   #6 (permalink)
Bill1013's Avatar
Whoops ---For some reason my cursor jumps all over when I go to favorites since I changed to IE8.
