Anyone with a DP tuner near Calgary AB - Diesel Forum - TheDieselStop.com
Old 09-07-2009, 12:51 PM   #1 (permalink)
I have a DP tuner, and I am nervous about doing the install myself and was wondering if there was anyone in my area who has one who has installed it themselves?
2002 F350 CC, SB XLT 6spd, Luk clutch, 285/75R16 Goodyear Wrangler Silent Armor
4" Magnaflow Turbo Back Exhaust
DP Tuner: 80econo, 60econo, 40tow high Idle
gjs1 is offline
Old 09-07-2009, 02:15 PM   #2 (permalink)
siderbox's Avatar
You can do it.
Just make sure you clean the board contacts where the chip plugs in.
Follow the directions, they cover everything if I remember right.
Take your time. Pay attention to detail. All will go well.
Welcome to guzzle's DP Tuner's Chip Installation Web Page
You might have to replace you clutch after you run a DP
Y2K DRW CC 4X4 Lariat
6spd stageII singles DP F6
siderbox is offline
Old 09-07-2009, 05:17 PM   #3 (permalink)
You Can Do It !!
Have a little confidence in yourself. Take your time.
Remember you can only accomplish one thing at a time so... When that one thing is done.... move on thru the directions.
2001 F350 Lariat DRW Crew Cab L/B
4x4 7.3 112K miles 3.73
Magnaflow 4" Exaust w/3 1/2" down AIS air
F5 DP-Tuner 40T,80E,120R tunes
SW Triple gauge pillar
6.0 Cooler - BTS trans
ford6x6 is offline
Old 09-07-2009, 08:13 PM   #4 (permalink)
woodnthings8's Avatar
Trim out the pcm plastic bracket! You can get away not trimming it out, but the cables tend to want to pull when sliding the pcm back into the bracket. I ended up trimming a section out of the bracket to allow the wires plenty of clearance room. Overall an easy job, just like the others have said.... Take your time.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
