My '01 F-250'S drivers side auto hub will not disengage out of 4wd. The passengers side works fine. I had disassembled and cleaned both hub assemblies. I have no problems with my heater controls. Does this still sound like a vacuum problem or am I dealing with something else. Thanks.
2001 F-250 4x4 Extended Cab XLT, Vortec Liner, Autometer 3-Guage, Full A-pillar Pod.
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
Tap the rim of the dial face of the lockout with rubber hammer while rotating as you were both forward and/or reverse.
Kent
>202K miles @ 070828
Do what Woodnthings says, remove both, dissassemble and clean, then lube. Should be good for several years..
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
Mine get stuck and I have had the vacuum capped for some time. I usually take a small pry-bar and wiggle the axle shaft in and out. This seems to free them.
remove the locking hub and push the white plastic plate in the bottom of the hub with a screwdriver. It should stay down when you push on it. reinstall the hub.
