Automatic transmission leaking like a mutha in reverse under load - Diesel Forum - TheDieselStop.com
post #1 of 23 (permalink) Old 06-03-2006, 03:09 PM Thread Starter
2001 Ford F350 Dually powerstroke
Ok here is the story.
I go to the dealer (stealer) to get the pinion seal replaced as the book calls for a torque spec that I cannot reproduce. I think it was like 400 ft/lbs or something like that.
Anyway I figure while it is in I will get the tranny serviced as it has not been done since I have owned the truck. They do a 'flush' by unhooking the lines to the cooler and running fresh fluid in while sucking the old fluid out.
Ok.. everything seems to be fine. I take the truck and trailer (tag trailer with 3100 pound race car) on a 6 hour trip to southeast GA. Check for leaks at the first gas stop and everything looks good.
Here is where it gets strange. I get to the race track and backup to park the trailer. The tranny proceeds to spew tranny fluid out the inspection plate in front of the transmission. The inspection plate has a little hole (breather hole? or fluid drain hole?) in the bottom of it and transmission fluid just pours out of the hole as fast as it can get out.
Only happens in reverse with a load (trailer and race car).
Does not happen in forward with a load.
Does not happen in reverse with no load.
Help.
Dealer keeps saying nothing wrong - sorry we can't reproduce the problem.
What do I do? This has never happened until the transmission flush.
Thanks for any input.
Todd
btcarter is offline
post #2 of 23 (permalink) Old 06-03-2006, 05:45 PM
Toorglide's Avatar
Re: Automatic transmission leaking like a mutha in reverse under load
mine did the same about 20k ago. i had it it 4H should have had it in 4L [img]/ubbthreads/images/graemlins/shrug.gif[/img] was putting too much pressure on the tranny and boiled the fluid right out, fortunatly the seal re-sealed but then 10k later i was rebuilding the tranny, was told to use 4 low EVERY TIME i back up with a load, have been ever since. mine did do fine for 10k though, then 3rd and overdrive went away, good luck
99.5 XLT SD Auto Xcab 4x4 Offroad
B\W Turnover in a long box,Harpooned,ProLiner srayin bedliner,Pioneer indash CD
4" pipe--turbo to 5" tip, Zoodad-ed, AIH nomo, De-Foiled
14" K&N cone Breather,4 Pos DP Tuner
Isspro EV Guages X3,Toned Badges
Hydrolocked motor at 162k <---- REplaced with a Caterpillar reman crate motor that had 3 injectors & 2 GlowPLugs and the Turbo canned with in the first year
Toorglide is offline
post #3 of 23 (permalink) Old 06-03-2006, 06:04 PM
Kev
South Georgia Motor Park?
Just curious, not too much on the tranny...my 97' did that when I overheated it pulling a trailer but I had overserviced it; probably not your issue here.
02' F250 CC 4x4 SWB 6-Spd 3.73, 85k
Tuff Country 5" Suspension Lift, 315 x 75 x 16 Buckshot Mudders, X-Treme Alloy 10" Wheels. Wicked Wheel, MBRP 5" Exhaust, AFE Stage 2 Intake, Coolant Filter. Legacy Custom Seat Covers front and rear (Best mod yet!).
Kev is offline
post #4 of 23 (permalink) Old 06-03-2006, 07:02 PM Thread Starter
It was actually more east than south I guess. Roebling Road Raceway.
4L? Do all automatic trannys have that? All I have seen on mine is Reverse. Plus it had never done this before the tranny service.
Any idears?
2001 Ford F350 Powerstroke 7.3
Automatic Transmission
btcarter is offline
post #5 of 23 (permalink) Old 06-03-2006, 08:13 PM
Only if it has 4 wheel drive. Is the fluid level right? Not over filled? Does it do this while moving or only after you stop? How many miles on your truck?
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #6 of 23 (permalink) Old 06-03-2006, 08:43 PM Thread Starter
135K on truck
Not a 4 wheel drive
Does not do it ever in a forward moving gear.
Only happens when it is in reverse. Although it does keep
leaking until you take it out of reverse and put it back in
a forward gear.
btcarter is offline
post #7 of 23 (permalink) Old 06-03-2006, 09:05 PM
Probably the front seal on the transmission. The flush may have losened up the crude around the seal and let it start leaking. At that mileage it should have already been flushed 3 or 4 times. The only fix I know would be pull the transmission and replace the seal. While you have it out you might want to replace the torque converter with an upgraded one.
Just my .02, Joe
post #8 of 23 (permalink) Old 06-04-2006, 01:25 AM
when in rev the trans comands higher pressure and blows out the front pump seal seal backing up under load the factory front pump seal is junk i work for ford and this is still a problem have the seal replaced with the aftermarket pump seal made with the viton rubber
jpb620 is offline
post #9 of 23 (permalink) Old 06-04-2006, 03:40 AM Thread Starter
I take it you have to pull the transmission to replace the pump seal?
Does Ford have the pump seal with viton rubber? Or is that something I have to do?
Thanks for all the input so far!
btcarter is offline
post #10 of 23 (permalink) Old 06-04-2006, 10:10 AM
My Photos: (5)
reverse has a taller gear ratio than forward, higer pressure is commanded, but its the heat from all the stock converter slip/added load/reversing that builds extra heat in the converter and relaxes the crappy ford seal even more and the fluid pours out. The "black" seal is an aftermarket piece, any tranny shop should have one. You have to pull the tranny to replace it. Would be an excellent time for a converter upgrade as the stocker is not very efficient or the clutch very stout.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
post #11 of 23 (permalink) Old 06-04-2006, 11:58 AM Thread Starter
Ok.. Looks like the tranny is gonna have to come out. Is this a shadetree mechanic job or a tranny shop job?
What would be recommended to do to the transmission while it is out?
btcarter is offline
post #12 of 23 (permalink) Old 06-04-2006, 01:59 PM
NCHornet's Avatar
You never did say if you checked the fluid level. These are classic symptoms of over filling with ATF. Does the fluid smell burnt? If it were me I would check the fluid level, if it ain't burnt you may be ok. I would then install a tranny temp gauge as well as Boost and EGT, you really should have these already, but anyway. I would then install a 6.0 cooler . This is the oil to air tranny cooler out of a 6.0 torque shift tranny. It is over 3X as big as the stock one you have. They can be had on ebay for about a C note, and install is very simple. My tranny temps haven't seen over 160 backing up my 8500lb TT in 90 degree ambient. Good luck.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #13 of 23 (permalink) Old 06-04-2006, 02:42 PM
My Photos: (5)
pan temp and converter temp are not the same, a huge cooler only cools the fluid after it has left the converter, the fluid puking will still happen.
1999.5 cc dually
post #14 of 23 (permalink) Old 06-04-2006, 03:20 PM Thread Starter
Yeah I checked the fluid and it was low after the spewage. It loses about a quart of tranny fluid during a backup and park it routine. Which usually only lasts about 3 - 8 minutes. 8 minutes being on the extremely long side. So, it loses fluid in a hurry.
Fluid does not smell burnt and it looks like it was poured out of the bottle it is so fresh.
btcarter is offline
post #15 of 23 (permalink) Old 06-05-2006, 10:16 AM Thread Starter
So what is better? Taking it to a tranny shop or the dealer for this work? I'm not too jazzed about the dealers around me. I have taken it in twice and been pretty much screwed over both times. If you recommend a tranny shop which one? Anyone know of a good transmission shop in the birmingham, AL area?
Thanks.
btcarter is offline
