Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 04-14-2009, 11:03 AM   #1 (permalink)
ColLonewolf's Avatar
Axle Question
Posted this in the 7.3L IDI section but got recomended to post it here anyone know if the axle/springs from an 01 E350 Van will fit an 89 F-350? Thanks.
Quote..... "I have been offered the rear axle out of a 2001 Ford E350 van. I know the vans did not change bolt patterns like the trucks did at least to some point but does anyone know if the springs will bolt right on or if the axle itself will bolt to my springs. This axle is the same gear ratio as mine but has the disc brakes and newer springs as it has only 80k as mine is an 89 and has at least 130K. Any info on this matter would be greatly appreciated. Thanks."
1989 Centurion Classic 350 4X4 (F-350 4door Bronco), W/93 7.3L IDI non-turbo, ZF 5-Speed(LUK)/BW 1356/Dana 60/Sterling 10.25, 3.55, Hypermax Turbo/Intercooler, 3 1/2" Exhaust/Pyro(inop), RDT, 265/75R16 BFG/AT on 16X8 American Racing Wheels 138K and still going strong
1983 300SD Turbo Diesel, 3.0L Inline 5, 4 Speed Auto, White/Parchment, VDO Boost Gauge, 215/60R15 Bridgestone Potenza RE960AS Pole Positions on 15X7 15 Hole Wheels, Straight Piped, 298K?
ColLonewolf is offline
Old 04-15-2009, 03:55 PM   #2 (permalink)
Standing behind the axle looking forward measuring from left side across to right side inside to inside = 45 3/4in, measuring outside across to outside = 51 3/4in.
Old 04-15-2009, 09:08 PM   #3 (permalink)
dlblazer's Avatar
Free bump for you. When looking for axles for 4x4's generally the van axles are narrower than the truck axles. I do not know if this is the case here. Regardless, I would expect the frame width to be the same and the spring perches to be in the same spot (only a tape measure can be sure).
Also, spring length could be different (if you want to use the springs). Be sure to measure all dimensions.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 04-16-2009, 10:21 AM   #4 (permalink)
