Bad Injector Pics - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-26-2010, 09:55 PM Thread Starter
Bad Injector Pics
Despite my superior searching skills (yeah right) I cannot find pictures of what the typical injectors look like after removal. Specifically, what I'm up to is: I removed the injectors from my truck and I would like to see what a comparable set should look like. Just kind of a "here is a good looking injector, here is one that is shot". Anyone know of something like this, or a good description of what to look for without disassembly?
RTJ1S is offline
post #2 of 4 (permalink) Old 04-27-2010, 12:15 AM
klhansen's Avatar
My Photos: (180)
Here are some pics of good injectors with bad o-rings.
The Smoking Gun --
But generally, you won't be able to tell a good injector from a bad injector. Well, unless the nozzle is broken off.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 04-27-2010, 09:03 AM
big_stroker's Avatar
The only real way to tell if an injector is bad or not is to put it on a flow bench and flow it and to take it apart and masure its specs.
IMO send them to a GOOD injector shop like Nate at Unlimited Diesel or Cass at Full Force Diesel to have them looked at and flowed and rebuilt if need be.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
516 HP and 1121 TQ - 4/24/10
big_stroker is offline
post #4 of 4 (permalink) Old 04-27-2010, 08:54 PM Thread Starter
Thanks for the replies; I removed my injectors, due to a long standing crank but wont start issue. I am going to send these to a well known 7.3 specialist, but I was just hoping for some type of flashing neon sign that says its bad. I figured it would have to be disassembled, so thanks again.
RTJ1S is offline
