bad oil leak under powersteering pump - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-26-2010, 02:30 PM Thread Starter
oopowerstroke4x4's Avatar
ok so this morning i went out and started my truck and notice a real bad oil leak. i climbed under the truck and found it leaking underneath the power steering pump on something that heads back towards the oil filter.anyone experienced this problem...my truck is an 00 7.3 litre with 436,000 miles so i know problems are gonna start to happen,but not sure if this is a gasket problem that could be easily fixed or not...also does anyone know where i can a breakdown of the 7.3 litre powerstroke so i have a reference to what this part might be..
2000 Ford F250 cc 4x4 short bed...35x12.50 r18, aftermarket wheels, diy tymar intake, straight pipe before tires with 6 inch rolled tip...428,000 miles still running strong
oopowerstroke4x4 is offline
post #2 of 8 (permalink) Old 12-26-2010, 02:49 PM
It sounds like your engine oil cooler has finally let you know it's there.HA,HA.You can purchase the rebuild kit from ford about $80 I think it's been a long time since I did mine.Your engine coolant runs this cooler as well as your engine oil.It can be a pain in the a@# to do if you have never done it or so I'm told.I paid my mechanic $50 to do it @$25 an hr.
themule67 is offline
post #3 of 8 (permalink) Old 12-26-2010, 02:50 PM
that is the oil cooler it needs a rebuilt kit $65 dealer
F250 SD
diy intake
4 inch turbo back
ccv dumped outside
paulf250 is offline
post #4 of 8 (permalink) Old 12-26-2010, 05:06 PM
RT
RT's Avatar
Here it is from a site sponsor for 59 bucks.
Replacement O-rings for Ford Diesel Engines
RT is offline
post #5 of 8 (permalink) Old 12-26-2010, 07:37 PM Thread Starter
i have been reading up on the engine oil cooler..has anyone personaly had to fix theres..was wondering how hard it is..i recently replaced the o rings in the water seperator..that was a walk in the park,but i have heard this can be difficult.
post #6 of 8 (permalink) Old 12-26-2010, 07:42 PM
RT
RT's Avatar
There are directions on the page I referenced above. I've read where some people had to use a little oomph to get the ends seated again, but for most of us, just lean into it.
RT is offline
post #7 of 8 (permalink) Old 12-26-2010, 11:18 PM
My Photos: (19)
I remember doing mine. It wasn't the easiest thing in the world, but wasn't THAT bad. A little lube and like he said, lean into it!
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #8 of 8 (permalink) Old 12-27-2010, 06:13 AM Thread Starter
thanks everyone for the help..now i just have to get the money to order my kit and get a day off to install..
