Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 04-13-2009, 08:33 PM   #16 (permalink)
woodnthings8's Avatar
I agree flushing a cooler 100% clean would be next to impossible. The Ford dealer says they run it for two or three hours on the flusher. Luckily mine was just starting to slip and didn't have a bunch of "parts" in the cooler.
2002 F-350 CCLB 4X4, HD4R100 , 4" Diamond Eye exhaust, Powerslot rotors, DP Tuner-F6, Autoenginuity, KCM S.S. HPX Line, S&B Filters intake, Autometer gauge pod, Inovations canopy,Banks Big Head wastegate actuator, 6.0L Trans Cooler, Zoo-dad, Dieselsite Coolant Filter, DVD and always looking to do more....
woodnthings8 is online now
Old 04-13-2009, 08:41 PM   #17 (permalink)
knoweigh's Avatar
Originally Posted by dieselturbo View Post
shifts through all gears but i seem to have to step down harder to get this beast moving.. used to be 2000 rpm now 23-2500. once it locks up in overdrive i have more power and better acceleration. also milage stinks. this is my first winter with this truck. starts at 16 degrees- no problem. but no power . i had a diesel suburban before this -stock - and it had much better acceleration. does this sound like a bad converter or trans. it pulls good in overdrive when locked. thanks andy. yes i know diesels have no power until warm. but this happens warm too. i expected this to be much quicker than suburban.
Are you totally set on limiting your issue to the tranny?
Hows boost? look normal? have you checked you up pipes, intercooler hoses etc?
My experience has been:
low boost, poor fuel mileage, and loss of power= either boost leak or exhaust up-pipe leaks.
If it's more of a loss of power ordeal, the tranny is the last place I'd look.
How about fuel filter? Clean fuel bowl? Smell any fuel up under engine which would signify possible bowl drain orings.
How's the engine valley on top? Dry?
just my $.02 worth.
y2k F250 170k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode AT, ext cab long bed 265/75/R16 E rated tires, Dp tuner 60t 60e 80t 80e, DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed up pipes, 4" downpipe & exhaust, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags. Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (1500lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 3200lbs empty; 12k loaded)
knoweigh is offline
Old 04-13-2009, 10:38 PM   #18 (permalink)
xfordtdm's Avatar
Originally Posted by Mark Kovalsky View Post
There is no way to flush a trans cooler and get all the junk out. If you reuse a trans cooler after a trans failure expect a second trans failure.
This is especially true with the top feed cooler style. The lines input and output from the top of the cooler allowing sediment to never evacuate and fill the bottom. The 6.0 cooler is much larger and the input/ output is from the bottom allowing no sediment to settle.
2001 f250: AFE stage 2, Banks Monster exhaust w/power elbow and bighead wastegate, autometer pillar guages, kcm crossover, ccv delete, ITP over boost annihilator, dp 6 pos stock, 40,60,80econ,100,120, BTS Tranny, FS2500 soot sucker bypass oil filtration.
xfordtdm is offline
Old 04-16-2009, 09:09 AM   #19 (permalink)
Nyghtryderz's Avatar
I need to know what the in line filter next to the white by-pass filter is? Is this the external Transmission Filter and what type of service does it need?
I tried looking it up and it said that it was a Fuel filter, but i thought that they only had one filter one the block for this year and model.
2001 Ford F-250 Diesel 4x4 XLT Super Duty
4" - 6" Lift with Super Lift shocks
35" Toyo Open Country M/T
Rough Country Dual Steering Stabilizer
Bully Dog Transmission Temperature Gauge
Prodigy P3 Brake Controller
122,000 miles
Nyghtryderz is offline
