Ball Joints - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-14-2008, 02:11 AM   #16 (permalink)
Banned
Tip...Make sure you install the new joints using the torque specs that come with the particular aftermarket brand (like Moog). It'll be on the paper stuck in the box with the joints. Those specs will be different that the Ford manual, and what you find in internet articles here.
Gooch is offline
Old 11-14-2008, 07:50 AM   #17 (permalink)
Originally Posted by westvandude View Post
My lower ball joint on driver's side is gone, assuming other side is bad too. Pre-runner style tilt on front tires. Fixed a clunk sound in front end after stepping on the brakes with repairing tie rod end, still had a clunk there after the repair so pulled front tire off and I was able to jiggle the rotor/bearing/studs 1/8" up and down and saw all the movement was in lower joint.
I ordered the complete ball joint kit from Your Premiere Source for Ford Truck Parts | Powerstrokeshop.com $291 plus $47 s&h (got an oil filter and fuel filter also). My local parts shop wanted $300cdn a side for the same parts.
I still have to source a good ball joint press. Gotta do a dodge 3500 after I do mine so thought I'd just buy the damn tool. Going to check and see what www.princessauto.com has.
Where on the Powerstrokeshop site is the ball joint kit? I searched for it and it just says no product found,and for that matter they only have ball joints for a 2 wheel drive.
SGnAZ is offline
Old 11-14-2008, 07:43 PM   #18 (permalink)
westvandude's Avatar
On their homepage click on the "Powerstroke Specials" link and you'll see them listed second item down.
Powerstrokeshop.com
Man... installed new seals and a u-joint on driver's side axle shaft during the day today. What a pain in the arse. The c-clips were pretty hard to remove. Otherwise the u-joint went in ok.
The bearing seal was something else. Tried beating it on with a piece of pipe and the seal started deforming. Couldn't find cast iron pipe big enough to make up a tool using the pipe flange idea. Ended up putting together some much larger stuff from 1 1/2 or 1 3/4" cast pipe from autoparts store. That worked but lemme tell you, you have to pound on that thing with a BIG hammer to get it on and real easy to put it on slightly offset. I couldn't believe the amount of pounding it took to seat it properly. The smaller axle side dust seal went on real easy in comparison.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
