barometric pressure sensor - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 03-28-2009, 05:11 PM Thread Starter
I've looked all over for this, can anyone tell me where the barometric pressure sensor is located in my truck--01 F250 7.3L-- Part # F8UZ-12A644-AA
Thank you,
Steven
2001 Silver F-250 7.3L 4WD, extended cab, 130k miles, BF Goodrich A/T 285/75; BTS auto tranny w/6.0 cooler, AIS severe duty intake and filter w/Zoodad mod, 6 position chip from BTS, 4" turbo-back exhaust, Magnaflow muffler w/5" tip, Speedliner sprayed-in liner, Monroe Reflex shocks, Isspro pillar gauges
sparvin is offline
post #2 of 18 (permalink) Old 03-28-2009, 05:36 PM
chuckster57's Avatar
It should be:
Passenger side of the engine, near the cowl (according to autozone)
It will have a three wire connector and a vacum line attached to it.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 18 (permalink) Old 03-29-2009, 02:49 AM
Originally Posted by chuckster57 View Post
It should be:
Yep what he said.
A device that senses barometric pressure for the engine control system. May be combined with a Manifold Absolute Pressure (MAP) sensor.
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203 T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
post #4 of 18 (permalink) Old 03-29-2009, 07:38 AM Thread Starter
Thank you guys, I have been looking under the dash and apparently that's where the older ones were. I'll get out there today and swap it out. Hopefully it won't be a problem.
sparvin is offline
post #5 of 18 (permalink) Old 03-29-2009, 09:00 AM
guzzle02's Avatar
I thought the Barometric Sensor was incorporated into the PCM in 99+ Powerstrokes.....
02 F350 EC LB 7.3 PSD SRW Lariat 4x4
BTS valve body - AIS Intake - 4" MBRP - SS HPX
Lift pump - Dahl pre-pump filter - WW
DPTuner chip - Z-series Gauge - TC Lock
Homepage:
guzzle02 is offline
post #6 of 18 (permalink) Old 03-29-2009, 01:26 PM Thread Starter
Well, maybe Guzzle's right? I went looking for this and can't find it still. Anyone got a pic? Can you be a little more descript as to pass. side, near the cowl? I just can't find it.
Thanks.
sparvin is offline
post #7 of 18 (permalink) Old 03-29-2009, 01:29 PM
PowerStrokn's Avatar
i dont know how you actually got a sensor but Guzzle02 is right for the 7.3L 99.5+ the baro is in the pcm.
2003 Sonic Blue Cobra loaded with power goodies.
2006 Black XLT Sport Package Crew Cab F-350 6.0L, Harley SD Head Lights w/ HID Conversion, Ready Lift Leveling Kit, 35" BFG All Terrain, MAC Intake, Custom SCT Programmer Tuned by Dave Guy of SGS Automotive, Magnaflow 4" Exhaust, ARP Headstuds.
PowerStrokn is offline
post #8 of 18 (permalink) Old 03-29-2009, 01:31 PM Thread Starter
Uh oh, looks like Guzzle's got another point--http://www.thedieselstop.com/archives/ubbthreads/1999EandD/forums.thedieselstop.com/archives/showflat.php-Cat=&Number=401871&page=22&view=collapsed&sb=5&o=& fpart=1.htm
Another guy reported 2000+ models have it in PCM
sparvin is offline
post #9 of 18 (permalink) Old 03-29-2009, 03:44 PM
My bad - good catch. Autozone is talking MAP sensor (and like me) assuming/guessing the baro is in there. Not on your (OP) truck.
Kent
>202K miles @ 070828
techkdb is offline
post #10 of 18 (permalink) Old 03-29-2009, 05:53 PM
klhansen's Avatar
My Photos: (180)
True. the Baro sensor was separate on the early 99's and migrated into the PCM for 99.5's
), AIS,
regulated return,
klhansen is offline
post #11 of 18 (permalink) Old 03-29-2009, 06:24 PM
I thought the baro and MAP sensor were the same thing.
Train Horns:
post #12 of 18 (permalink) Old 03-29-2009, 06:30 PM
klhansen's Avatar
My Photos: (180)
Nope, one measures Barometric Pressure, and the other Manifold Absolute Pressure. They might be identical sensors, but the MAP sensor is hooked to the manifold. If you disconnect the MAP sensor hose, it'll measure Barometric Pressure.
), AIS,
regulated return,
klhansen is offline
post #13 of 18 (permalink) Old 03-29-2009, 06:32 PM
ford_doctor's Avatar
Just to verify, the 7.3L DI BARO sensor was incorporated into the PCM on 1999.5 and newer engines. The stand alone sensor on pre-1995.5 engines is located under the driver's side dash near the steering column.
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #14 of 18 (permalink) Old 03-29-2009, 06:44 PM
Thanks.
Boost Relief Valve +
its (MAP) in the second picture - on left side/edge.
Kent
>202K miles @ 070828
techkdb is offline
post #15 of 18 (permalink) Old 03-29-2009, 06:50 PM
klhansen's Avatar
My Photos: (180)
its in the second picture - on left side/edge.
That's the MAP sensor.
), AIS,
regulated return,
klhansen is offline
