Batteries draining while running - Light on - Diesel Forum - TheDieselStop.com
Old 11-19-2009, 12:16 PM   #1 (permalink)
03 7.3 I replaced the alt and batteries last month old alt burned up. I think my current problem caused it. My battery light is staying on longer and longer each week. It is taking 15 to 20 minutes of driving until it goes off but as much as 40 mins. I tested the alt and it was putting out 40 amps. Could it be glow plugs staying on? The light will go out after a while but will flicker on an off. Sometimes just touching the throttle will make it go off.
imrich is offline
Old 11-19-2009, 05:44 PM   #2 (permalink)
My Photos: (19)
The light shouldn't stay on because the glow plugs are on. I've been going through this on my truck right now too. You've measured the aperage output of your alternator, but the light measures the voltage. It's not putting out the proper voltage if your little light is coming on. If your old alternator blew up (wow, I'd hate to see what it looked like) then how is all your wiring? Sounds like you've got a few wires in there that aren't doing their job.
One thing I would suggest is that you run a 6 or 4 gage wire from the stud on the back of the alternator directly to the battery. The other thing you need to check is the other 3 wires going to the alternator.
Let us know what you find out.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 11-19-2009, 07:23 PM   #3 (permalink)
The alternator tested out fine, actually took it into a shop. Checked and cleaned all wires. Once the light finally goes out it charges the batteries like normal.
When driving with the batt light on the lights are very dim. When the batt light goes off there is a dramatic increase in about of light from the headlights. The problem does not seem to be dependent on RPM at all.
imrich is offline
Old 11-19-2009, 09:33 PM   #4 (permalink)
Pulley, Tensioner, Belt
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
Old 11-20-2009, 12:25 AM   #5 (permalink)
Powerstrokin400's Avatar
My Photos: (18)
40 AMPS seems really low, do you have the Heavy Duty Towing Package? I may be wrong, but if memory serves me correct, when I replaced my alternator with a NEW "Ford" alternator for Heavy Duty Towing Package, it was a 130 AMP alternator. My truck came with the HD Tow Pkg. What was your battery voltage? You need 12V to run, & 12.5V is full battery charge, and a minimum of 13.5V is needed from your alternator (with all your lights & accessories on) to charge a battery. CK Pulleys & tensioner....that's cheap & easy to check.
2003 F250 XLT 7.3L, Auto, FX4, Crew Cab, Long Bed, 6.5" Pro-Comp all spring lift & Firestone HD Rear Air Bags, BFG KM2 37x12.50x17 tires on Eagle 17x10 Rims, 4" Turbo Back Exhaust & muffler delete, Bully Dog Programmer @ 120 Hp setting ALWAYS, Machined & Bellowed International Up-Pipe Kit, Autometer Overhead Gauges (Boost, Pyrometer, Trans. Temp), Custom Pre-Filter Ram-Air with K&N filter, "John Wood" Custom Stage I Transmission, 6.0 Billet 3 Disk T/C, External T/C Lock-up switch, 6.0 Trans Cooler, Hughes Racing Deep Structural Pan, and a few more goodies. Now spinnin' AAM Rear & Dana Spicer Front 4.30:1 Gears with Warn Premium Locking Hubs.......I do a lot of towing.(13,000 lb 33' Toyhauler & 21' Ski Boat). 84,568 miles as of 11/09
So. Cal. Fireman
IAFF Local 2342
Other Rides:
2006 BMW 330i Sport
1992 Camaro RS 5.0L, 25th Anniversary
1990 Mustang LX 5.0 Sport, 5spd., 25th Anniversary
Powerstrokin400 is offline
Old 11-20-2009, 12:47 AM   #6 (permalink)
What is the voltage reading off the back of the alternaor? A weak tensioner can cause the alternator not to charge properly, if a 6 ga or larger wire is run from the alternator to the pass side battery, use an in line fuse, in case of a voltage spike.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 11-20-2009, 05:05 PM   #7 (permalink)
My Photos: (19)
Your stating that there is a significant increase in the voltage at a certain point is this: the glowplug circuit is turning off and the charging circuit is now allowed to charge at it's full capacity. Yes, the glow plugs will stay on for a while after the engine is started.
That said, you should still be able to maintain 11+ volts while the glow plugs are on which should NOT set the light to come on. If you cannot, then there is something wrong. If the shop is telling you the alternator is good, and the wires are good, then definitely check your belt and tensioner.
Placing a fuse in a new line is a good idea, but it will not protect from voltage spikes. Fuses are an over-current protective device, they don't have anything to do with voltage. Most fuses are rated at a couple hundred volts allowing them to be used for either DC or AC where they can see 120+ volts. On a 12volt DC system you would want a voltage spike protection of only +/-5volts. IF you want to protect your batteries from a voltage spike then you need to install a Regulator which will keep the voltage from going over a certain limit but will allow current to pass at will. There really isn't much of a need for that on our trucks as there is a Regulator built into the alternator. The fuse would protect the batteries if an alternator would happen to short circuit or if you are like me and pull the alternator off the engine without removing the wires to work on something and it shorts out as it touches something it should.
BTBBT is offline
Old 11-21-2009, 09:52 AM   #8 (permalink)
CPUNeck's Avatar
My Photos: (13)
Ha, I thought I was the only one to do that
OP, why not confirm what your "phantom" load is. When you first start your truck, ensure the Glow Plug Relay (GPR) is passing voltage to the GP's. Then when you suddenly get the extra juice, pull over and check that GPR again. There should be no voltage passing between the big lugs.
Could be a couple possibilities; 1) Your GPR is bad, and sticking or leaking, 2) The feed cable on the rear of your alternator is corroded (check behind the wire jacket, especially if on the bad alt there was evidence of burning/charring, 3) Corrosion at the battery terminals. Again, check behind the connector, the corrosion can travel up the wire.
All in all, with the described symptoms, sounds like a reproducible event, point to the GP system. I'd start there... hope that's a start. Oh and on the belt tension, there are visible indicators on the tensioner that indicate when it is out of service limits, so you shouldn't have to do an actual deflection test of the belt.
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
SVO Conversion Updated SVO stuff
CPUNeck is offline
