Battery cables - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 01-23-2009, 10:36 PM Thread Starter
Battery cables
Hey guys I am in need if a new positive cable. My cable has split and corrided at the passenger battery. I went to Autozone and they said they do not have diesel cables. Went to O'Rileys and they gave me one marked 97 to present. I went to put it in and at the starter relay connection on the stock cable it is connected to both sides of the relay. The one O'Rileys gave only has one connector. I am assuming this is the wrong one. Anywhere else I can get a new cable, or can I cut the battery cable on the stock one at the battery and put some other type of connector for the two batteries to connect to. This is on a F-250.
2000 F-250 4x4 Lariat Ex-Cab Short-box
1974 Bronco
GWBronco is offline
post #2 of 4 (permalink) Old 01-23-2009, 11:11 PM
van_350sd's Avatar
My Photos: (80)
This gent has the thick 3/0 Ga. Cables as an option, I would get a custom set of the 3/0 from him.
Custom Battery Cables F350 cables
2000 E350-Super Duty Ext. Mobile LivingRoom-7.3LPSD
van_350sd is offline
post #3 of 4 (permalink) Old 01-24-2009, 02:04 PM
I bought the OEM cable from one of the sponsers, about $75 or you can try the dealer.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
post #4 of 4 (permalink) Old 01-24-2009, 05:51 PM Thread Starter
I got the one from O'Rileys to work. Thanks for the input guys.
1974 Bronco
GWBronco is offline
