battery light - Diesel Forum - TheDieselStop.com
Old 11-16-2009, 02:34 PM   #1 (permalink)
dieseldickson's Avatar
battery light
hey guys my battery light came on during my drive to work on my 02 350 today no other signs or problems with starting what is it tellin me?
02 F 350 Crew cab long bed 4x4 6" Rancho 20" chromes with nitto swampers, straight piped and K&N lookin for more
dieseldickson is offline
Old 11-16-2009, 03:17 PM   #2 (permalink)
woodnthings8's Avatar
Probably telliing you it won't start after work today. Usually when the battery light comes on that means the alternator is not working. Once the voltage drops to a set amount the battery light will come on.
Here is the description of how the light turns off after start-up:
When the generator builds up enough voltage to energize the voltage regulator, voltage is applied to the PCM. The PCM upon receipt of the generator charging voltage, removes the ground to the instrument cluster and turns off the charging system indicator.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-16-2009, 03:19 PM   #3 (permalink)
so basically how much is an alternator and can i jump it to get it home thanks
Old 11-16-2009, 03:30 PM   #4 (permalink)
You can get one from about $125 on up to $500
FORD F SERIES DIESEL TRUCK 110 AMP ALTERNATOR 02 03 8316: 8316-3-110 AMP REGULAR OUTPUT DB Electrical Starter-Alternator
Ken
TSB Information
Old 11-16-2009, 03:36 PM   #5 (permalink)
can i jump it if it acts dead when i get off and does it matter which battery i hook up too?
Old 11-17-2009, 09:46 PM   #6 (permalink)
the one on the passenger side is closest to the starter. But my truck had the battery light on for forever and nothing ever seemed wrong but after about 50,000 or more miles i went ahead and changed it just to take the light away because i was tired of looking at it. Go to NAPA and get one of their heavy duty alts, that way you can bring your core in and knock a little off the price. always a good thing!
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 11-17-2009, 10:45 PM   #7 (permalink)
try checking the connections on the battery before you drop any coin on parts. mine was just a loose black wire.
WildRover is offline
Old 11-17-2009, 10:55 PM   #8 (permalink)
gdp
ditto, I have the same year, same light, and 3 days later the truck was dead, it was the alternator. I bought one at NAPA, I think around $125 with the lifetime warranty, and have changed it twice since then about every 2-3 yrs, free except for my labor which isn't much because it's a 10 minute job to change. The NAPA guy told me it's a design problem that they put out too much current without enough cooling...get the lifetime warranty and change it whenever the light comes on.
2002 F-250 CC Lariat
gdp is offline
Old 11-18-2009, 10:33 AM   #9 (permalink)
I bought one from NAPA a couple months ago. They didn't even have a "lifetime warranty" option for any of their alternators. Their regular alternator was a 1-year warranty, and their heavy duty was a two-year.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
