Best additive for storing fuel... - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-05-2008, 03:20 PM Thread Starter
What is the best (meaning economical and effective) additive long term storage of ULSD diesel fuel? Brand recommendation and source appreciated.
It needs to be stable for up to 6 months.
Tim T.
TTBadDog is offline
post #2 of 5 (permalink) Old 03-06-2008, 08:33 AM
Tim T.
You really only need to add an anti-fungal additive. Use Bio-Bor. It will prevent algae from growing in the fuel which will clog the filters. It is also good practice to pour the fuel trough a good filter/strainer before it goes into your tank.
Early '99 F350 SRW.3:73 Gears DP Tuner Chip,AFE MAGNUM FORCE AIR INTAKE,FORD REPLACEMENT TORQUE CONVERTER, REMOTE START, NEW Delphi CPS, Ford Blue CPS as SPARE ,BLACKCLOUD DIESEL HX OIL LINE.
pandersen is offline
post #3 of 5 (permalink) Old 03-06-2008, 11:04 AM
Kanman's Avatar
Wernt you getting a 300 gallon tank or something like that?
I would dump a bottle of Power Service in and forget about it. PowerService in the white bottle is about $5 at Wal Mart, and will do exactly what your needing.
Kanman is offline
post #4 of 5 (permalink) Old 03-06-2008, 12:24 PM
haul_n_horses2's Avatar
My Photos: (17)
Tim T.
Racor Bio-Cide and PowerService Diesel Fuel Supplement!
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #5 of 5 (permalink) Old 03-06-2008, 06:22 PM Thread Starter
Yup, I am picking up a 275 gallon 10 gauge tank. Comes with a hand stroke pump and 12 VDC pump. I have a good place to put it out of the weather. I will use fill it up in the fall and use till empty. Seal the tank up tight and in the spring dump 5 gallons of gasoline in it, slosh around a bit and drain it out. Put this in my lawn mower. Fill it up with 93 octane and some stabilizer for use in the super charged boat. 93 octane for the boat can be a chore to find. I will test the 93 before placing in the tank. The 275 gallons will get me through to mid to late summer.
Repeat process until broke.
TTBadDog is offline
