Best Torque converter? 2001 PSD 7.3L w/ 4R100 - Diesel Forum - TheDieselStop.com
post #1 of 38 (permalink) Old 12-28-2010, 10:05 PM Thread Starter
Who has best converter for 4R100 behind 7.3.
Had new converter put in, think its basically a reman, but has triple disc set-up. problem is just like the OE original converter, it seems to loose/drives thru the converter while its unlocked.
and if towing and take off hard its just screaming in low gear, not moving very fast, then slam into second and lock up same time then since wasnt moving very fast in low/unlocked. sorta lugs for moment then gets going.
2011 F350 CC Lariat FX4 DRW-Dark Blue Pearl met./Ebony leather interior~ B&W turnover G.N.
sam2 is offline
post #2 of 38 (permalink) Old 12-28-2010, 10:14 PM
westvandude's Avatar
I got a bit of the same prob. Guy who built mine isn't around anymore. I think low stall rpm works better than OE stall rpm if you tow a lot.
Sometimes I think that the trans is a bit at fault for being tired. Putting in a new NADP unit next year or sooner.
Everyone raves about precision industries converter but it's a lotta money... paying for the name. Can get other good triple clutch units for half that.
Over-revving and not upshifting seems more trans prob than converter but just guessing.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #3 of 38 (permalink) Old 12-28-2010, 10:34 PM Thread Starter
I have heard of this John Woods on converters and I think he uses Precision Industries, not sure if he has a special spec on his stuff or not.
mine is even loose when floored from dead stop and drives thru the gear changes unlocked. not if you take off part throttle then floor it it will lock going into second and accelerate much better.
thinking of a low stall RPM myself, but dont want to spend a fortune on one.
sam2 is offline
post #4 of 38 (permalink) Old 12-28-2010, 10:49 PM
If you don't have the cash for PI's $1100 unit send Adrian Tavano a shout tavano72@yahoo.com around $600 for HD 3 clutch unit, low stall another $60-80 I think. He knows his stuff, got one in my truck. Used to sell'em under powerstrokeconverters.com but not enough demand. Forum member too.
post #5 of 38 (permalink) Old 12-28-2010, 10:59 PM
Could your slipping be a delayed 1 to 2 shift? The 2001s had a bad second gear clutch, diode. Do a search for mechanical diode. See if the symptom matches.
brian6674 is offline
post #6 of 38 (permalink) Old 12-28-2010, 11:12 PM Thread Starter
Shouldn't be. Trans worked fine at 200,000 miles when took it to my tranny Guy for converter to be changed out. Arnett Racing transmissions. he does my glides in racecar, prob does 3 E4OD/4R100 trans a week. Anyway prob my fault for not asking for a low or extra low stall speed when he got a me a converter, although it does have triple disc lock up. but never had probs with original single disc slipping that I was ever aware of. It's a Champ converter, OE stall speed with triple disc.
Tranny althought it was fine and asked him to only change the converter, he pulled tranny out, completely disassembled it, cleaned in steam parts washer and rebuilt it with Trans Go "tugger kit", all new clutches and bands. He even installed an extra clutch in 2nd and put in a dbl element sprag (twice torque capacity) or mechanical diode. so its beefed up pretty good, save for aftermarket H.D. shafts, which sure I dont need at my level
sam2 is offline
post #7 of 38 (permalink) Old 12-29-2010, 08:30 AM
That's all I can say, is the Brian Thompson from BTS transmissions put in a Precision Industries, "Stallion" torque converter in my X rebuld, 7 years [& 130k] ago...
Painted purple.....
I'm happy with it
The only downside, is that it doesn't have a drain plug in the converter...
So that's all you can get is about a 7 qt change, out of a capacity of nearly 20 qts...unless you do a power flush....
But, a 20 qt power flush @ $12/qt [Schaeffer synthetic oil] adds up real quick..
That's why I'd rather do the 7 qt every year...
XS_SUV
Graupp is offline
post #8 of 38 (permalink) Old 12-29-2010, 08:34 AM Thread Starter
Painted purple.....
I'm happy with it
Heard of Brian of BTS, well known for his trans, think my local guys is prob just as good, atleast unless your a truck puller or something. Didnt know Brian used P.I. converters. thought he used another brand. Also heard this John Wood (not sure who he is) also used P.I. converter too
sam2 is offline
post #9 of 38 (permalink) Old 12-29-2010, 10:38 AM
X6TC ... take a look... here ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #10 of 38 (permalink) Old 12-29-2010, 12:29 PM
aklim's Avatar
How many miles on this trans? If it is a fresh rebuild, get a PI unit since they will give you a free restall within 2 yrs if needs be from the last time I bought one. If you have miles on it, I wouldn't put a new TC on it that is more expensive than stock and that is if you must change it. Once the trans breaks, you have to pay to have the TC cut apart, cleaned, welded back and balanced. Cost me $400 the last time.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
post #11 of 38 (permalink) Old 12-29-2010, 12:35 PM Thread Starter
trans has about 20,000 miles on it now, fresh extra 2nd clutch adding 33% more torque capacity and dbl element sprag. Tranns go tugger kit, pump mod etc.
sam2 is offline
post #12 of 38 (permalink) Old 12-29-2010, 12:37 PM Thread Starter
Did you ever run the GTP38r turbo with stock injectors before upgrading to stage II BPD injectors?
and what is BTS "Big oiling system"?
sam2 is offline
post #13 of 38 (permalink) Old 12-29-2010, 12:39 PM
aklim's Avatar
I suppose you could get away with installing a PI unit but it costs about $1000. That way you can get it restalled if you don't like the stall speed.
aklim is offline
post #14 of 38 (permalink) Old 12-29-2010, 12:40 PM
aklim's Avatar
No. The GTP38R was just installed a month ago.
That is where BTS sticks another oil pump (reverse rotation) on top of your pump. Terminator also uses dual pumps but theirs is one behind the other.
aklim is offline
post #15 of 38 (permalink) Old 12-29-2010, 03:32 PM
Racer_X's Avatar
Happy Holidays
To celebrate The X6TC's success: We have free decals, you pay the postage until the year is out! She will run all day long with the high $ TC's! Watch the powertrain on mega fuel + nitrous haul *** in my signature!
Free Decals: They are Big boy bold decals 9 1/4" L x 4 3/4" high. Racer X style!
Mr advertise with us: You have mail....
Thanks,
Racer
POWERFLOW BY RACER X - 1997 F-350 Twin Turbo charged 7.3 Power Stroke Diesel fueled with 473 cc's of diesel plus nitrous, equipped with a Custom
Racer X E4OD transmission making 800 r.w.h.p. on video! The first successfully Twin Turbo Charged 7.3 PSD!
Owned & sponsored by :
Racer_X is offline
