Black something on Trans dipstick...need help - Diesel Forum - TheDieselStop.com
Old 11-21-2009, 06:17 PM   #1 (permalink)
Todes's Avatar
Hey guys,
02 7.3 auto trans, 4r100. I pulled the dips stick to check the fluid level, and when I got to the end there was a line of black.....oil/grease. It seems like more like old grease than oil....I will try to get a pic in the morning. The line was on the side of the fluid level indicator that rested on the dip stick tube.
Going to do a trans service too it anyway, it was due. My question(s) I guess is, what could it be from? And is there anything I should look for while I have the trans pan off when I do the service?
Little extra info if it helps, I have a leaky boost boot that has been leaving some oil in the valley.
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 11-22-2009, 12:42 AM   #2 (permalink)
woodnthings8's Avatar
You need to pull the pan. I would assume you have a large amount of clutch and torque converter material. I have never seen that much in a pan (where it registers on the stick). Hopefully it is something else, but pulling the pan will tell the story.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
