Block heater heat output? What does your temp. ga. read? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 01-15-2007, 03:03 AM Thread Starter
Does the block heater need replacing every few yrs. like a hot water heater element in your home water heater? I could swear mine used to do a better job and show a warmer temp on the gauge when I first turned the key on after an overnight plug in. I use a 12 ga. 3 wire cord 75 ft. long. (closest outlet to my truck)
Just curious what everyone's temp. gauge shows after an overnight plug in, and at what outside air temp.?
Jim
2000 F-450 7.3L DI Powerstroke DOM 7-99 stock
fishnfool186 is offline
post #2 of 10 (permalink) Old 01-15-2007, 03:10 AM
klhansen's Avatar
My Photos: (180)
Re: Block heater heat output? What does your temp. ga. read?
I don't think I've ever seen the temp gauge register when plugged in. Of course it's usually below 20F when it's plugged in, and I typically only run it for 2-3 hrs.
I'd guess that's a touch colder than where you are. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Unless you have some real crap in your cooling system, the block heater won't go south on you like the one in your water heater. It gets coated with a new batch of calcium coming from the water entering the heater.
If your block heater is working at all, it's most likely pretty close to the output (1000W) it had when new.
), AIS,
regulated return,
klhansen is offline
post #3 of 10 (permalink) Old 01-15-2007, 11:16 AM
Around freezing my gauge starts just below the bottom of the normal running range, runs quiet and the heater works immediately. It has been around 0 the last few nights. The gauge starts on the peg and the truck rattles a little. The heater still warms me up lightyears ahead of my wifes Subaru on a cold start. I think I read somewhere that the block heater will keep the water about 50 above ambient?
Early 99 CC 4X4 SWB BTS Auto, 4" turbo back, 5.5" lift, Toyo MT315/75r16, Gauges, AIS, DP Tuner.
KingE is offline
post #4 of 10 (permalink) Old 01-15-2007, 01:21 PM
My transmission gauge always registers above the coldest tick mark when I have mine plugged in ( below 40F I like it to warm up faster [img]/ubbthreads/images/graemlins/wink.gif[/img]
The engine temp rarely moves from it's lowest post but I always know it is working based on the trans gauge.
02 EX PSD Limited
76 F150 soon to be 4wd rockcrawler
83 VW GTI SCCA ITB Rally car
01 YZ426F, 85 IT200
bjhous is offline
post #5 of 10 (permalink) Old 01-15-2007, 02:00 PM
I use block heaters on several engines. Most are industrial though. Ive never had one that would warm the engine up enough to register on the temp gauge. If you feel the side of the block with your hand it may feel just barley warm depending on the ambient temp.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
post #6 of 10 (permalink) Old 01-15-2007, 02:30 PM
remedm's Avatar
Turn the heat on when you first start it. If you get air that is
warmer than outside, Then it is working. I think its a case of
work's or doesnt work. But I have been wrong before.
2002 CC F-350 SB SRW 4X4 TOREADOR RED
DP-TUNER NO-START, MOD STOCK, HIGH IDLE, DRIVE THRU, 40 TOW, DECEL, 60 TOW, 60 ECON, 80 ECON, AND RACE
BTS TRANNY (NUFF SAID)
; 6.0 COOLER
DIESELSITE BOOST RELIEF VALVE, 203^ THERMOSTAT AND HOUSING, MAX A/C VALVE AND COOLANT FILTER
ATS TURBO HOUSING, FORD A.I.S., OILGUARD BY-PASS, 4" MAGNAFLOW STRAIGHT PIPE, SIDE EXIT,
NCHORNET'S CCV MOD, POR-15 OIL PAN
ISSPRO A-PILLAR PYRO/BOOST/TRANS, ISSPRO ENGINE, OIL TEMP AND VOLTS OVER MIRROR
MARINCO MOD, LED ID BAR, HEATED SIGNAL MIRRORS, LED BRAKE AND TURN SIGNAL BULBS FRONT AND REAR
RHINO BED LINER, SIRIUS RADIO
AMERICAN EAGLE WHEELS WITH 305-70-16 NITTO TERRA GRAPPLERS WITH A 2" DONAHOE LEVELING KIT
TRUCK BUILD DATE 1/8/02
BTS BUILD DATE 1/8/07 AT 41K
remedm is offline
post #7 of 10 (permalink) Old 01-15-2007, 03:21 PM
haul_n_horses2's Avatar
My Photos: (17)
Depending on the ambient temperature, I have seen as high as 100 after 10 hours of block heater use. That was on a night when the temperature was in the 30s rather than dipping to the predicted temp of below 20 (My daughter unplugged the cord from the timer so she could plug in her stereo while working on her dirt bike. Forgot to plug it back into the timer. Grrrrr). Normally, I plug in for 3-4 hours and when it is 20 outside, I will see a coolant temperature of about 70. BTW, I have a digital coolant temp sensor plugged into the drain plug in the driver's side of the block. I do not think the OEM gauge moves until you are over 100 but I may be wrong, I do not look at it anymore.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #8 of 10 (permalink) Old 01-15-2007, 03:22 PM
Rickie's Avatar
The actual measuring range of your temp gauge is way too high to register anything when you use your block heater under normal conditions.
My pyrometer will show 50*F to 70*F depending upon how cold it is outside. That's not the water temp, but it tells me the heater is working when it's -30*F, like this last Thursday & Friday.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
post #9 of 10 (permalink) Old 01-15-2007, 03:26 PM Thread Starter
Thanks to all. By your input, I guess mine is still doing all it's supposed to do.
Jim
post #10 of 10 (permalink) Old 01-15-2007, 04:14 PM
Flywheel's Avatar
If I plug in for a few hours - it will register on the lowest mark of the range, as well after a few seconds )I guess it needs to circulate...
Check your electric meter plugged in vs. not - it should spin pretty well - I think it will either work or not.
There is probably a resistance measurement I could take and post (with the ambinet temp today). It's actually 27 just outside of Austin!!!
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
