Block heater tripping GFCI? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-08-2005, 10:17 PM Thread Starter
My first winter in cold weather ... as it got down below freezing, I was using a timer to have the block heater go on a few hours before morning. Its been working fine, cold starts not a problem. Tonight, first real storm with snow and sleet. When the timer kicked on, the GFCI on a connected outlet would trip. Eventually, I traced it to the plug on the truck. As soon as I plugged it in, the GFCI would trip. Is this typical? It has been working well until just tonight.
2002 F250 Crew Cab, Lariat, 4X4; Edge Juice w/Attitude; Edge Evolution; MBRP 4" turbo back stainless exhaust with 5" tip; AFE stage 1 intake with torque tube; ATS ported compressor housing; auxiliary trans cooler; ARE MX Shell for when I'm not towing; LineX in the bed; KC Hilites backup lights under the bumper; Cobra 75 WX ST CB mounted in console; Pioneer radio with backup camera
BGGreenBeast is offline
post #2 of 5 (permalink) Old 12-08-2005, 10:35 PM
Wolley's Avatar
Re: Block heater tripping GFCI?
Not typical but quite a few will do it. My own truck will not trip a GFCI but my old 6.5 chevy would. There can be a very small leakage to ground, 4 milliamps, that is not dangerous but will trip a ground fault interrupter. If you have a meter check the prongs on the block heater to the truck body. If the resistance to ground is over 100K ohms then all is well.
Parking it outside where even a small amount of moisture gets in the plug will cause it to trip.
Try plugging it straight into the wall without the timer. Some of the timers are as cheaply manufactured as they can be.
Try a different extension cord also.
Was just another Whiny Chevy driver
Since this is my 3rd Ford in 7 years I guess I may be convert.
2012 F250 CC, Shortbed, 4WD, Aggie maroon
Towing 2011 Cougar High Country 5W
Wolley is offline
post #3 of 5 (permalink) Old 12-09-2005, 05:56 AM
NCHornet's Avatar
Make sure you are using a big enough timer and extension cord, then I would try and keep all connections as dry as possible. I did the Marinco mod and it keeps the connection good and dry and makes it much easier to plug in.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #4 of 5 (permalink) Old 12-09-2005, 07:24 AM
any rain/snow or damp on the plug will do it on a gfi. they are looking for a short and it dont take much to tell them to trip and cut the current. a fog is all it takes on mine
99 f350 4x4 cc 145,000 miles fuel tank,lines ais
BTM
wilson61 is offline
post #5 of 5 (permalink) Old 12-09-2005, 07:41 AM
Wobblin-Goblin's Avatar
My 6.2L Chevy trips the GFI due to a short somewhere.
[img]/ubbthreads/images/graemlins/confused.gif[/img]
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1994 Dodge 3500 SLT Dually 5.9L Cummins NV4500 5spd US Gear "splitter" Exhaust brake 4x4
RETIRED: 1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
NRA Life member
Wobblin-Goblin is offline
