blowing grey smoke and knocking 1999 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 01-26-2010, 12:05 PM Thread Starter
no warning just started knocking and blowing heavy grey smoke. injector??? what would cause this? starts right up idles drove it 100 yards and shut her down. knocking loud as heck.didnt want to wreck anything. 1999 7.3 turbo
mario714 is offline
post #2 of 7 (permalink) Old 01-26-2010, 01:39 PM
jroller's Avatar
Youve got a failed (cracked injector tip) or youve blown an injector o-ring. Dont run the motor or youll hydrolock it. Heres what to do.
1) Locate the bad injector(s). This is time consuming because you shouldnt run a contribution test because of the chance of hydro locking the motor. So pull you injectors, Id start with the drivers side.
2)When you find the torn o ring or cracked/fractured tip that is allowing fuel to gush into the cylinder replace with a new injector and o rings.
3)Pull the glow plug on that bad cylinder, (its probably screwed up too) and hand crank the motor to get the fuel out of it.
4)Install ne GP along with your new FI youve already put in and start the truck. Its gonna smoke alot at first intil it all burns off but the audible knock should be gone.
Heres what mine looked like......
Name:	Cracked injector.jpg
2001 PSD 7.3 auto DP Tuner, 4" TBE, KNN Intake (with filter charger), CCV Mod, DB Starter, Stancore GPR, ITP Overboost, John Wood installed valve body. External coolant filter. International Up Pipes.
1994 RAM 4x4 Cummins KNN, 3GSK, AFC Spring, #10 Plate, BD Valve Body, KDP, SCHWITZER S300 turbo 4" TBE.
jroller is offline
post #3 of 7 (permalink) Old 01-26-2010, 02:06 PM
jroller's Avatar
Heres some video
http://www.youtube.com/watch?v=t4hDG_IvBHw
jroller is offline
post #4 of 7 (permalink) Old 01-26-2010, 06:42 PM Thread Starter
thanks for the information. that is exactly what shes doing same sound same smoke. was wondering if its just the o ring can i just replace that or should i still get a new injector. wit the way my lucks going im sure its cracked though lol. thanks again. i see the oring kits that are for sale but what about a rebuild kit with a tip know where to get them?
mario714 is offline
post #5 of 7 (permalink) Old 01-26-2010, 08:56 PM
tattoocharlie's Avatar
My Photos: (5)
well depending on how much the rebuild kits are ,id get one so you have it.becayse of murphys law,if you dont get it youll need it.but it you wont need it,but will have it and will ensure a long life to your injectors.according to murphy
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #6 of 7 (permalink) Old 01-27-2010, 12:10 AM
jroller's Avatar
Either way your gonna have to pull the injectors. Im assuming these are not new injectors (although my injectors had less than 2 weeks it happened to me) and are probably well worn.
I say if youve got that injector out replace it. The tip of that injector was super heated the last time your truck ran combined with non stop knocking.
If that fixes your issue consider yourself lucky because Orange County Diesel on 3 different occasions said the only way I would fix that issue was with a new $7,000 motor.
You also need to ask yourself, if the tip did fracture off, what happened to the tip of the injector? Did that "hydro-knock" pop my headgaskets? Bend a rod?
As stated earlier, I would locate the culprit, do a compression test if you have access, but at least slap another inj in and see how it runs.
jroller is offline
post #7 of 7 (permalink) Old 01-30-2010, 03:20 PM
Yup, it was my injector. It wasnt cracked just had some carbon build up
on it, so it was sticking open.
99 powerstroke is offline
