blowing instrument cluster and throttle fuse - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-13-2011, 10:22 PM Thread Starter
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
uncles 2001 f250 keeps blowing the instrument and throttle fuse, where should i start looking for a short? thanks!
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #2 of 9 (permalink) Old 04-13-2011, 11:16 PM
lance1955's Avatar
OD Shifter wires are probably broken. Check and or replace shifter. Thats where I would start.
2002 Excursion 7.3L 200K+, After market tranny cooler, diesel site transmission filter kit, coolant filter kit and complete boot kit, bilstein shocks. Original transmission with mobile syn ATF
lance1955 is offline
post #3 of 9 (permalink) Old 04-14-2011, 07:47 AM
RT
RT's Avatar
Here's a link to Ken's write-up:
https://docs.google.com/viewer?a=v&p...M2Q5YjdmODQ4NQ
you can unplug the OD wire so you can drive the truck until your new one comes in.
RT is offline
post #4 of 9 (permalink) Old 04-16-2011, 03:19 AM
My 03 6.0 did the same thing. I removed the wires and button and put the button in the dash next to the cubby so it wouldn't chafe anymore.
The Extractor is offline
post #5 of 9 (permalink) Old 04-16-2011, 08:48 AM
woodnthings8's Avatar
Link above didn't work for me, So here is the direct link.
Transmission Shifter O/D Wiring Chafe Repair
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #6 of 9 (permalink) Old 04-16-2011, 09:02 AM
bigb's Avatar
Now thats good old American ingenuity!!! got any pics?
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 160K, BFG Rugged Terrain 285s, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, ELC, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Red Head steering gear, Battery Tender & 2 Marincos.
bigb is offline
post #7 of 9 (permalink) Old 04-16-2011, 12:41 PM
Bill1013's Avatar
Haven't seen a 2001 but should be the same as a 1999. Shifter lever with OD button is $58 at dealer. Three phillips head screws underneath the steering column holding the cover, remove it, then to remove the key cartridge, there is a pin bottom side of key, push it up and pull cartridge out, top cover comes off then, one pin or bolt holds the shift lever in, unplug connector. If the wire is bare just repair it or install new lever. Check it out before buying new lever, don't take long to do.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #8 of 9 (permalink) Old 04-17-2011, 12:34 AM
post #9 of 9 (permalink) Old 06-09-2012, 11:00 AM
Great write up and a real easy fix. The chaffed area was identical to the photo however two wires were chaffed and I only "discovered" the problem when I pressed the OD off and closed the short circuit and blew the fuse. Fortunately it happened before I pulled onto the open road.
This fix should be considered a maintenance item for any 7.3.
SteelJ is offline
