If you are running the tiny little plastic line that comes with most gauges then I would run it through the large rubber gromet in the firewall close to the big PCM connector. There is lots of room in a ring around that grommet to put a small hole and shove the tube through.
Others will suggest that if you have an auto trans then to put a small hole through the firewall where the clutch MC usually sits. I have a clutch MC there so that wasn't an option for me.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
