Brake fluid reservoir empty but no evidence of leak - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-20-2011, 09:14 PM Thread Starter
My 2002 Excursion with 70,000 mi. brakes went soft and I checked the fluid. It was basically empty so I refilled it and started pumping the brake pedal. The reservoir emptied again and there is no sign of a leak. Where is the fluid going? Is the master cylinder conected such that it can get pulled into the engine or exhaust?
Thanks, Tom
graythom is offline
post #2 of 5 (permalink) Old 06-20-2011, 09:21 PM
F350_6's Avatar
Welcome to TDS. Instead of just adding fluid and pumping the pedal, you really need to bleed the brakes and purge all the air out of the lines before you even consider looking for leaks, or heavens forbid, driving it somewhere.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #3 of 5 (permalink) Old 06-20-2011, 10:53 PM
Greg03PSD's Avatar
Have you ever changed the brake pads? With 70,000 miles, they may be about worn out, depending on how much you torture the brakes. As the brake pads wear, they get thinner. As they get thinner, the caliper pistons move farther and farther out of the caliper. Check your brake pads to see how close the pad backing plates are to the rotors - if you have almost no friction material left, you've just figured out where your brake fluid went - it's still in the system, but it has migrated from the master cylinder to the caliper piston cylinders and you haven't actually lost any fluid. When new pads are installed, you typically have to crack open the bleeder screw when you push the caliper pistons into the calipers - this lets all the extra fluid out. If you don't do that, it pushes all the excess fluid back into the master cylinder and may overflow the master cylinder (not to mention is pushes dirty old brake fluid back into the brake system).
If the master cylinder level got so low that you got air in the system, you'll have a fun time bleeding the system. You might need to bleed the master cylinder as well to get all the air out. With the added complexity of the anti-lock braking system, it makes it that much more difficult to get all the air out.
2003 F-250 4x4, 7.3L PowerStroke
6" Skyjacker Z-link lift, 35" MT Baja ATZ tires
18" Wheels
Warn 16.5Ti winch w/ hidden mount
Front & Rear ARB Air Lockers
Dynatrac Free-Spin Front Hub Conversion
Edge Juice Programmer
Fabtech Ladder Bars
AutoEnginuity w/ Ford Enhanced package - Southern California - Just bring beer!
Greg03PSD is offline
post #4 of 5 (permalink) Old 06-21-2011, 12:48 AM Thread Starter
The brake pads are in really good shape. I have new ones but the ones on the vehicle are nearly as thick as the new ones. I know, I find that hard to believe but it's true and the rotors are in very good shape. This is something that happened suddenly and the fluid is definately leaking somewhere but there is no sign of a leak. Therefore I am left wondering where it could possibly be going! I have done brake jobs on many vehicles over the past 50 years but this one has me puzzled.
graythom is offline
post #5 of 5 (permalink) Old 06-21-2011, 02:58 AM
Go inside the truck and pull the carpet back in the area of the drivers feet. There is a rod going from the brake pedal through the fire wall. The oring that seals it can sometimes leak. The oily pad/carpet may provide the answer.
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
