Broke the heater plug-in off the harness. Darn. - Diesel Forum - TheDieselStop.com
Old 10-09-2009, 11:28 AM   #1 (permalink)
Anyone done this and what's the fix, new harness from the stealer
or go to home depot and buy a replacement female three pronger ??
It was pitch black out but it looks like only two wires on the harness end
but I could have miised the 3rd wire, it was early.
My luck sucks. Good news is I've got about a week before it gets below freezing again.
Cris
Formerly CrisinColorado, Owner of a dark shadow grey '02 PSD F350. CrewCab Dually 6-spd. Most options. Diablo 70+ H.P Chip. Magnaflow S.S. Turbo Back 4" System.. A.Meter 3gauge stuffed with Autometer's. Speed Grill & chrome lady adornment on the flaps. Use it to pull 29 ft. Forest River Toy Hauler 5er. It holds a 1965 U-2 Mallock Ford powered Vintage Road Racer (900#'s of fun!). Also own a '78 Volvo 242GT that had a Ford heart transplant. '90 5.0 & matching 5speed. Rollbar, 6pt belts...ready to race
JustCris is offline
Old 10-09-2009, 11:46 AM   #2 (permalink)
Todes's Avatar
I would think that you could just go to the local hardware store and grab a new female end. The only thing that I can think that could be a consern is the voltage requirements....but that should be for the wires only. So you should be able to get a new end, strip some wires and re-wire the new end on and be good to go. lets see what the other good people of Dieselstop say!
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 10-09-2009, 12:26 PM   #3 (permalink)
woodnthings8's Avatar
Mine has a male three prong plug for the block heater. Is that what you broke, or the connector on the filter base for the block heater? If you just ripped the cord out any 15 amp three prong plug will work. Or you can get a new harness HERE. Also look at the plug adapter that you can install to eliminate the hanging cord deal. Marinco Block Heater Plug Mod
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 10-09-2009, 12:53 PM   #4 (permalink)
Hey wood, thanks for the reply, it's the 3 pronger which is why I thought it kinda odd to only see two wires coming out of the back of it.
Thanks for the 15 amp clue.
Do I need to pay attention to what goes where on the back of the soon to be 'new' plug, or any wire into any side (if it's only two) ?
Thanks again,
Cris
JustCris is offline
Old 10-09-2009, 01:39 PM   #5 (permalink)
It is only a heater so, two wires are ok, Think of it like a light bulb. The heater element is just a light bulb with a big element. Back several years plugs were not polarized and every one just plugged them in. Now they are polarized or 3 prong to make sure you plug it in the best way. They may put the ground plug on so you plug it in correctly to the wall socket. I will have to take a look at mine but I would think there should be three wires, but it may not be required as the truck sits on rubber anyway so it really isn't grounded.
Usually the left blade of the outlet is the neutral side and the right blade is the hot side.
Ken
TSB Information
Old 10-09-2009, 01:51 PM   #6 (permalink)
klhansen's Avatar
My Photos: (168)
I second and third (can I do that? ) the Marinco Mod. I've had one on my truck for many years. Had the cord break off flush with the rear of the original plug, and put on a heavy duty plug temporarily, then installed the Marinco recessed plug. Never looked back.
It'll be a grounded (3-wire) cord. DEFINITELY connect all three wires to the plug. If the hot wire happens to chafe it'll energize the whole truck unless the ground is connected, which will then trip the breaker, protecting you.
If you were to touch the truck with a hot wire shorted to the chassis, it'd surely curl your hair, and might even kill you. It wouldn't be good to be holding on to your truck doing a dance and not being able to let go.
Here's the diagram for plugs and receptacles: Plug and Receptacle Configurations
It'll be a NEMA 5-15P configuration.
Hard or no-start? Check Here
klhansen is offline
Old 10-09-2009, 02:12 PM   #7 (permalink)
Cris
A week before freezing? You haven't seen tomorrow's forcast...High temp in Denver of 33*, low 24*. You're correct about your luck....
You can get a flush weatherproof outlet at Bass Pro for around $16 in the boat section. Just bore a hole in your bumper and install. If your cord is not long enough, be sure to use 14 gauge wire and a GOOD butt splice adequately sealed from moisture.
2001 F250 Lariat, -SOLD-
460/950 Corrected Prior To Water Injection and Spearco IC.
13.974 @ 95.65mph
2008 Cummins Truck Fest 4WD Diesel Champion
'07 Duramax Classic, Leather, Sunroof, Bone Stock.
DZacc is offline
Old 10-09-2009, 02:39 PM   #8 (permalink)
Yep, just walked outside & checked, it's 3 wires, one was tucked back inside the factory electrical tape harness cover stuff. Definately going to mull over the marincomod. Now I just need to figure out which truck wires correspond to the diagram's for wiring up the plug. As it's voltage I'll remember to lick my fingers before touching anything.
JustCris is offline
Old 10-09-2009, 02:43 PM   #9 (permalink)
Sheesh, quit trying to cheer me up, ok ?? I don't need to get up @ O'dark thirty, should be ok (famous last words!).
JustCris is offline
Old 10-09-2009, 07:50 PM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (44)
The Marinco plus was designed to be a ship-to-shore plug, to plug the boat into shore power while it's moored at the docks. But there are other brands of the same thing, including the ones available at BassPro shops and sold under some name other than Marinco. Normally, you'll have a female plug on the wall of the house, connected to the "boat" by a heavy extension cord. The female end of the extension cord plugs into the male end of the cord on the boat or, in this case, truck. So you need the male Marinco or equivalent plug.
The block heater draws 1,000 watts, or 1 KW, so be sure that the extension cord and all connections can handle 1 KW without overheating.
SmokeyWren is offline
Old 10-09-2009, 10:25 PM   #11 (permalink)
So I took my block heater plug off of the filter base and rang out the wires on my plug. Look at the pictures so you can see how it should be wired. You should be able to use a meter to do the same, just might need a helper to reach both.
[IMG]/IMG]
Ken
TSB Information
Old 10-10-2009, 10:18 AM   #12 (permalink)
bigb's Avatar
Originally Posted by woodnthings8 View Post
This is the view from the backside?
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Battery Tender & 2 Marincos.
bigb is offline
Old 10-10-2009, 10:30 AM   #13 (permalink)
Thats the male plug in view for the normal hanging plug. The W is the neutral wire or white in house wiring. The H is hot or black in houses. Use it for the back if doing the plug mod mentioned above.
Ken
TSB Information
Old 10-10-2009, 06:43 PM   #14 (permalink)
Thanks for doing that Wood. I appreciate the great input.
Cris
JustCris is offline
Old 10-19-2009, 11:58 PM   #15 (permalink)
bigb's Avatar
Cool I just ordered 2 of them, 1 for the block heater and 1 for the battery tender. Work is slow this month but this is a mod I can afford!
bigb is offline
