Broken Glow Plug????? - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 04-02-2011, 03:52 PM Thread Starter
Hey Boys,
You guys have been very helpful in your advice on replacing my glow plugs. Well, 7 out of 8 went great!!! Unfortunatley #3 didn't come out very well! It was difficult getting the old one out, as there was constant pressure as I ratcheted it out. Well, the sleeve and the tip came out, but the internal heating rod stayed in the cylinder. This is the internal medal rod that runs through the body of the glow plug, the piece that heats up. I can get a needle nose vice grip on it but it won't budge!!! This is one of 2 cylinders that have been out for awhile, this one could be the one that has been out for 2 years!
Any help would be appreciated greatly!
Thanks!
Gordie
00 Excursion
7.3 Powerstroke
gordob is offline
post #2 of 15 (permalink) Old 04-02-2011, 07:05 PM
RT
RT's Avatar
They make a glow plug removal tool for this problem. An example is this:
Removal Tool, Engine/Trans/Driveline Tools | Toolfetch
I've never used one, so if you do go this route please take pictures and consider doing a write-up. There are much better prices on e-bay.
RT is offline
post #3 of 15 (permalink) Old 04-02-2011, 08:13 PM
F350_6's Avatar
Spray some penetrating oil in the hole and let it soak. See if that loosens anything up.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #4 of 15 (permalink) Old 04-03-2011, 09:59 AM Thread Starter
I tried the penetrating oil, no luck yet. That tool you reccommend looks like the ticket RT, however, plug has already broken off and came out. The heating element is stuck in there, w/ no threads or hex to grab. I'm waiting to hear from a few diesel doctors, but I'm gearing up for having to get into the cylinder for removal
Sounds like I should have stopped removal when the plug wasn't coming out normal! There was constant tension on the removal. On the others, once you get them to turn, you can thumb-turn them out. This one was tough!
I'll keep you posted!
Gordie
gordob is offline
post #5 of 15 (permalink) Old 04-03-2011, 03:27 PM
klhansen's Avatar
My Photos: (180)
Try some carb cleaner. It'll be a bit more agressive than the penetrating oil. If the innards came out of it, you might be able to gently screw a long sheet metal screw into the sheath and use that as a puller. You'll have to be careful not to swell the sheath inside the bore and wedge it in tighter. You might try cranking the engine over and see if the compression will help push the piece out.
Hope you can get it out without pulling the head. What brand plugs were in it? Some are said to cause that type of problem.
), AIS,
regulated return,
klhansen is offline
post #6 of 15 (permalink) Old 04-03-2011, 03:32 PM
If you feel lucky, you could start it. If the combustion pressure doesn't push it out, you are probably going to have to pull the head. If it falls into the cylinder while it is running, you could bust the block.
444-4D is offline
post #7 of 15 (permalink) Old 04-03-2011, 04:33 PM
bugman's Avatar
My Photos: (12)
Can you get ahold of anything with a peir of Vise Grips needle nose pliers? If you can you can try this trick that Dale Isley wrote up.
If you get a plug stuck because of a carbon head on the end of it, you can fashion a puller from a small needle nose vise grips to get it out. Take a look here:
GlowPlugTool1 pictures from cars photos on webshots
I used a long bolt to replace the stock adjustment bolt on the vise grip. For a slide weight, I used a couple acorn nuts off a semi welded together, but you could use about anything that will slip over the diameter of the bolt. You end up with this:
GlowPlugTool2 pictures from cars photos on webshots
Use the vise grip to grab the end securely, then use the slide to knock the plug back into the engine. A little carb cleaner and a good yank will usually get it out. If it wedges tight again, just repeat the process until you get enough carbon knocked off to remove the glow plug from the head.
Much easier and quicker than pulling the head. Torque spec for installing the plugs is 14lbs ft (168lbs inch).
bugman is offline
post #8 of 15 (permalink) Old 04-03-2011, 11:41 PM
klhansen's Avatar
My Photos: (180)
That's a slick tool.
), AIS,
regulated return,
klhansen is offline
post #9 of 15 (permalink) Old 04-04-2011, 09:43 AM Thread Starter
Wow, Bugman, I think you're on the right path! The only thing I've been able to grab it w/ has been needle nose vice grips! My buddy has a slide hammer and was thinking of trying to weld something to the tip of the heating element rod so that he can use the slide hammer. Also, this is a plug that has been out of commissionfor possibly 2 years, so the carbon build up could be extensive. Is there anyway to apply heat to this rod to help break the carbon away? Also, do you think that this rod is too hard of a metal to weld to if we need to?
Also, you say that knocking the rod down into the engine is the best way to start. Hopefully, the needle nose don't let go, then the rod is in the cylinder....ugh!
Ok, I'm excited to try this, will keep you posted!
gordob is offline
post #10 of 15 (permalink) Old 04-04-2011, 10:11 AM
bugman's Avatar
My Photos: (12)
One other thing that you might try if you have a boat dealer in your area is a carbon solvent that Mercury Marine sells. From what I understand it eats the carbon away if there is excessive build up. As far as welding something onto the tip, I wouldn't try it. You loose that tip of metal and you are into head pulling.
Once again I can't take credit for that puller ides since I copied it from a write up that Dale Isley did qute a few years ago.
bugman is offline
post #11 of 15 (permalink) Old 04-04-2011, 10:59 AM Thread Starter
I hear ya about that tip falling, that's the same concern we have about the vice grip hold. We're going w/ the vice grip option first.
I've got a good buddy who owns a marina, he reccommends Carbon Guard which is a fuel additive. I've got a bottle right here that I use on my boat!
We're getting after it right now! Thanks again!
gordob is offline
post #12 of 15 (permalink) Old 04-04-2011, 02:10 PM Thread Starter
Well, no movement yet. I have made a good slide hammer vice grip tool. One thing I've noticed has caused more concern. I took apart an old glow plug and realized something. The heating element rod that is stuck in there is actually 2 pieces. A smaller diameter upper pice that fits into a larger diameter piece that is the bottom portion that is in the cylinder head. My concern is that I may pull these two pieces apart, leaving the bottom portion down by the head. I'm assuming it's sooo carbon fouled that it's fused in place.
Just not sure if I should keep pounding on it!
Any thoughts Bugman?
gordob is offline
post #13 of 15 (permalink) Old 04-04-2011, 03:26 PM
bugman's Avatar
My Photos: (12)
See if you can't find some of that carbon fowler remover that you just spray onto the part. Either that or PB Blaster or some carb cleaner. Just soak the dickens out of it and it should come out sooner or later, just take your time. Do you have any idea of what type of glow plug was in it that is stucked? There are some that would swell the end and are a royal pain in the back side to get out. Autolights come to mind as the worse ones.
bugman is offline
post #14 of 15 (permalink) Old 04-04-2011, 05:21 PM Thread Starter
OK, no luck so far. Soaked it in some older industrial strength carb cleaner and we'll get back after in the a.m.! The plugs that are in there are the originals, so, not sure what they used. It doesn't look like they get bigger toward the bottom, but did notice they are 2 pieces, the upper 1/3 piece is much thinner while the bottom 2/3 piece is wider.
gordob is offline
post #15 of 15 (permalink) Old 04-05-2011, 01:40 AM
klhansen's Avatar
My Photos: (180)
Those don't sound like stock Beru manufactured Motorcraft glow plugs. They are the same diameter from just below the threaded portion to the end. Yours must have been changed out since the truck came from the factory.
), AIS,
regulated return,
klhansen is offline
