Buzz test -all passed, but Cylinder Contribution Test fails #3... - Diesel Forum - TheDieselStop.com
Old 02-18-2007, 04:17 PM   #1 (permalink)
olddieseldude's Avatar
My Photos: (16)
I attached Auto Enginuity to my truck the other weekend. The buzz test was good but #3 failed the Cylinder Contribution test. I've not lost/used any oil in the last 2500 mile. Does this mean a new injector is needed at that location?
The truck has always (purchased 10/05) had a bit of a miss at idle but very faint (wife couldn't hear it) and AE previously showed all cylinders doing their part. My fuel mileage has been good (18-19 city) until the last 3 months or so. My fuel mileage is down a little now (1-1.5mpg city). I had a substantial fuel leak at the Fuel Filter Drain Valve but that's been stopped. Now cold weather, less than 20 degrees for a month. Once warmed up I'm not seeing anything from the tail pipe except some steam in single digit weather.
I just have a definite miss developing at all rpms. Friday I drove round-trip from Indy south to the Madison In, a 1-3/4 hour drive one way. The truck sat for 3 hours before making the return trip. The miss was present the whole trip. The miss used to come and go a little, shutting the truck off and restarting it could produce a smooth idle, but seems to be constant now. The miss is visible in the exhaust plume in the cold weather.
Other than this the truck starts quickly, easily, and runs good. There are no leaks.
What do you think?
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 02-18-2007, 04:46 PM   #2 (permalink)
Re: Buzz test -all passed, but Cylinder Contribution Test fails #3...
I think I would put a injector in the #3 hole
2011 F250 Lariat CCSB 4x4....
catdiesel0631 is offline
Old 02-18-2007, 05:08 PM   #3 (permalink)
Kickin Y2K's Avatar
My Photos: (5)
Move injector 3 to another hole and see if that new hole shows up as failing before spending money on an injector.
Bill 2000 X550 4x4
Kickin Y2K is offline
Old 02-18-2007, 05:34 PM   #4 (permalink)
while your under the V/covers inspect the Interior Harness plug good.If its loose get the cheesey clips for it to keep it locked together or replace it
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
Old 02-18-2007, 08:19 PM   #5 (permalink)
JimTJr's Avatar
My Photos: (20)
Just making sure, did you have it well warmed up when you ran the test? (oil needs to be up to temp, from what I understand)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 02-18-2007, 08:34 PM   #6 (permalink)
My Photos: (16)
Thanks for the all the responses.
JimT,
Yeah, I had driven it for at least 30 minutes prior to that test. It was shut down just long enough to get my laptop out and hooked up to the truck.
Old 02-18-2007, 08:40 PM   #7 (permalink)
Excavator's Avatar
My Photos: (11)
First I would suspect a poppet screw loose.
Second I would check armature clearance on that injector as well as check for oil flow from the oil spout and compare it to other injectors
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 02-18-2007, 09:35 PM   #8 (permalink)
My Photos: (16)
Jim,
Help me out here. You're talking to a relative newcomer to the diesel thing. What and where is the poppet screw?
Is it in this picture?
Edited:
I may have found the answer in this post...
Old 02-18-2007, 09:43 PM   #9 (permalink)
Excavator's Avatar
My Photos: (11)
When you have the valve covers off you start engine and look at each injector. You will see oil spitting out of each injector from the spout. You can't miss it. If one is spitting not the same as the others, then susspect that the poppet screw is loose or armature plate clearance is out of spec. The way to check poppet screw is to remove the 4 screws that hold down the solenoid on top of the injector. Then remove the spacer and you will see a square armature plate. In the center of the plate is poppet screw.
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 02-18-2007, 09:52 PM   #10 (permalink)
My Photos: (16)
Thanks Jim,
The other post that I found just as you were replying makes it sound like the answer is still a new injector because I won't be able to fix the problem myself anyway, do you agree?
Old 02-18-2007, 09:54 PM   #11 (permalink)
Excavator's Avatar
My Photos: (11)
it could be just a loose poppet screw and you sure could check that.
Here are some pics, look at pics 1 ,2, 3 and 4
pics
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 02-18-2007, 10:11 PM   #12 (permalink)
My Photos: (16)
So you think the screw shown in pic 4,5,&6 could be worth a few hundred dollars to me? Cool! Can that be checked on the truck? If not I probably need an injector oring kit at a minimum, right?
Old 02-18-2007, 10:42 PM   #13 (permalink)
Excavator's Avatar
My Photos: (11)
no need to remove that injector to check the screw,just dont drop any screws that hold the solenoid on. If you were to do all injector orings then yes pull all of them out. I would still at least check the armature plate clearance before reinstalling.
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 02-19-2007, 09:33 AM   #14 (permalink)
I have never done this but if there is potential for dropping anything make sure you stuff shop rags or something onto any potentially exposed areas that would allow a screw to fall into your engine!
Joe
2000 F350 4x4 Bright Red w/ Grey 40/20/40, DRW, CC, L.B., 7.3 w/ Auto, Ltd. Slip 4:10, Cmpr Pkg., Factory Aluminum Rims, T/S Mir. AM/FM Single CD and Cassette
http://www.realcountryonline.com/home.asp, Open Wheel Racing www.scrafan.com, Team Roping www.roperssportsnews.com, Observed Motorcycle Trials ( www.atatrials.com & www.trials.net) and Cycling
SprintCarCowboy is offline
Old 02-25-2007, 10:52 PM   #15 (permalink)
My Photos: (16)
Well folks, since I work outdoors under a carport and it's colder than you know what around here and I had never attempted anything like this before, I decided that could not afford to spend too much time diagnosing the problem while the valve cover was off. My window of opertunity is small this time of year. Yesterday was low 20's here but today made it to 40 by late morning, so I decided to go for it. I needed to just get in and get out as quickly as possible.
I had purchased a Ford remanufactured injector from the PowerStrokeShop Friday and proceeded to change out the injector, inspect electrical wires and connectors. Thanks to all those who have contributed to this forum I successfully changed it out. The patient is alive and running as good as before, but that's the problem, it's running exactly the same. My problem remains the same, #3 fails the Cylinder Contribution Test.
Remember it passes the buzz test. Where do I look next?
