Re: A/C blows hot after running fine then gets cold again?
I JUST WHENT THROUGH THE SAME THING ON MY O2 REMOVE THE AC CLUTCH AND PUT A SMALLER SHIM IN PLACE OF THE ONE YOU TAKE OUT THE SHIM IS IN THE THE SHAFT OF THE CLUTCH BE CAREFUL WHEN YOU REMOVE THE CLUTCH OR YOU WILL LOSE THE SHIM.I THEN ORDERD NEW PARTS TO REPLACE THE CLUTCH AS IT WAS WORNE BAD. THE CLUTCH IS 3 PARTS FIELD,PULLY,AND CLUTCH . SORRY FOR THE CAPS I JUST LOOKED UP
02 cc drw 4x4 7.3 ranch hand headach rack uws tool box line x crome badges billett grill rease rails in bed goose/5th wheel connex 3300 c.b 206,000 +miles
03 reg cab drw 7.3 xl 12ft flatbed
2 2000 sea doo gti
2000 coachmen 281 rb 5th wheel
1983 chris craft 251 catlina.
2003 anderson 8x24 goose neck.
1999 crosley b/p autotransport.
1983 case 245 diesel 4x4 tractor.
2000 horton 7x16 cargo trailer
1996 E250 gas burner 351 cargo van.
2004 F150 supercrew 4x4 wifes truck.
