CAC Tube Drooling Oil - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 11-30-2013, 06:22 PM Thread Starter
Dr. Snow's Avatar
Send a message via Skype™ to Dr. Snow
My passenger side cac tub seems to be drooling quite a bit of oil by the y manifold. Not sure if this is a sign of my turbo going or something else. I had adout a quarter cup of oil on top of the manifold today. I have never modded my crankcase vent. It is still stock. Thinking of doing it now to see if the oil is coming form a seal in the turbo. Any ideas would be apprecieated.
Early 1999 F-250 SuperDuty 7.3 Liter 6 Speed Manual Trans, AIS Air filter, MBRP Exhaust, Powerslot rotors with Hawk pads, Luk Clutch with double roller bearing pilot bearing modification. DT444E Water Pump with Filter.
Dr. Snow is offline
post #2 of 13 (permalink) Old 11-30-2013, 08:59 PM
ReefBlue's Avatar
Turbo seal would mean oil out of the exhaust.
There are three rail plugs on the high pressure oil rail (front middle and rear of rail), they have O-rings that could be leaking.
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #3 of 13 (permalink) Old 11-30-2013, 10:13 PM Thread Starter
Dr. Snow's Avatar
Yah, I replaced those tonight. they've been sitting on my desk for a month because i saw some seepage. I cleaned everything up and took it to the engine wash. Drove about half an hour and had oil dripping from the CAC boot on the pass side. The clamp is tight and i just cleaned the pipes and boots this summer. I keep the engine pretty spotless! I hate working on grease pits. I used to work on old LMC snow cats with tons of hydraulics. The frames where covered in oil when i started. Fixing the steam jenny was a priority!
Dr. Snow is offline
post #4 of 13 (permalink) Old 11-30-2013, 10:39 PM
ReefBlue's Avatar
Then you'll need the boots from dieselsite.com. they don't leak at all
Sent from AutoGuide.com Free App
ReefBlue is offline
post #5 of 13 (permalink) Old 11-30-2013, 11:11 PM
91diesel's Avatar
Do you suspect a more-than-usual amount of oil in the tubes?
Check your air filter, if it is excessively dirty, it will cause excessive oil in the intake tubes. If you inspect the compressor side of the turbo and find excessive oil on both sides(inlet and outlet of compressor), the problem is likely a clogged air filter allowing oil to be sucked into intake. If there is oil only on the compressor outlet, then your turbo seal is leaking.
91diesel is offline
post #6 of 13 (permalink) Old 11-30-2013, 11:22 PM
jpciron's Avatar
I got my boots from riffraff. I am very happy with them, no leaks or oil/dust residue.
2003 7.3 F-350 XLT 2WD CC, 285,000K,4" Back~ 6" S.S. Miter Stack, International bellowed up pipes, K&N Intake W/Riffraff 6637 Filter,Ebpv delete,Garrett38r Turbo, Garrett high flow outlet, Stage 1 Injectors, PHP Hydra W/GearHead Tunes, Riffraff Plenum inserts, , Riffraff IC and plenum boots, Powder Coated Blue IC Tubes, Pricol Optix- Pyro,Boost,Trans , Hutch and Harpoon mod, Baldwin pre-filter,Rear Shackles,Custom box 12s behind rear,Kicker,Bluray,HDTV's
"The Constitution shall never be construed to prevent the people of the United States who are peaceable citizens from keeping their own arms."
jpciron is offline
post #7 of 13 (permalink) Old 12-01-2013, 03:47 AM
NYB
Only the passenger side is seeping? Not the driver's side at all? Hmmm...
NYB is offline
post #8 of 13 (permalink) Old 12-01-2013, 09:06 AM
ReefBlue's Avatar
If the boots themselves aren't leaking, then you're getting oil between the manifold and the boot coming out--are they tight? I think they're too thick to have been sliced through by mistake.
Is the plenum bent from being overtightened? When I replaced my manifold boots, I got the riff-raff plenum reinforcements to make sure I could gorilla them down without an issue.
Unless your EBPV is spraying oil and it just looks like the boot leaking. Not much else in that area to leak.
ReefBlue is offline
post #9 of 13 (permalink) Old 12-01-2013, 10:43 AM Thread Starter
Dr. Snow's Avatar
Pulled intake on turbo this am. Everything looks okay. I think I just have a little bit of an over abundance of oil in my intercooler. I'm gonna run it up the highway later today for a service call. With everything clean in the valley I should be able to see what is leaking. I don't think it is the ebpv. I replaced it all last November. While doing the clutch and up pipes. And the oil that was in the valley was right under the y,
Not back to the ebpv valve. The ebpv has been working hard already this year. It was 6* at my house yesterday.
Dr. Snow is offline
post #10 of 13 (permalink) Old 12-01-2013, 06:16 PM
klhansen's Avatar
My Photos: (180)
It would be unusual for only the passenger side CAC tube boot to be leaking as it's downstream of the intercooler. The oil would have to get all the way thru the intercooler for it to wind up there.
A short run after cleaning it up is a good idea. Check the HPOP hose connection on that side as well as the oil gallery plugs. It may be an o-ring rather than the CAC tube boot.
Took a run up the valley yesterday and the thermometer on the wife's Escape said minus 18 at one point. :brrr: The truck has been resting in the driveway since Wed eve. Had a heat wave this morning at 1F.
), AIS,
regulated return,
klhansen is offline
post #11 of 13 (permalink) Old 12-01-2013, 09:07 PM
jpciron's Avatar
Klhansen,
That's fricken cold..
jpciron is offline
post #12 of 13 (permalink) Old 12-01-2013, 09:30 PM Thread Starter
Dr. Snow's Avatar
Took a forty minute drive. About halfway I stopped and checked and that boot was dripping. Not as bad as I believed but dripping non the less. Looks like the threads on that clamp are a little gauled in one spot. I'm gonna order a couple constant torque clamps from napa tomorrow. I'll clean it up and hair net it and see what it does.
I love winter but I hate it when it's that cold!
Dr. Snow is offline
post #13 of 13 (permalink) Old 12-01-2013, 09:31 PM
RT
RT's Avatar
Kevin's other ride is down...
Sent from AutoGuide.com App
RT is offline
