carrier bearing / center bearing squealing got any ideas - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 12-12-2005, 12:07 AM Thread Starter
powerlifter405's Avatar
I first when I heard this squeaking/squealing sound I thought it was a front hub bearing and after I had to put everything up on stands and actually get the drivetrain running I was able to trace it back to the carrier bearing. [img]/ubbthreads/images/graemlins/confused.gif[/img] ***? I figure I have to pull it and see if the drive shaft is chewed up since I have no experience w/ it.
Anyone have experience w/ this before?
"New" 05 CCLB 4wd 6leaker No payments
sold
Sweet lookin' BLACK 02 F-350 XLT CC PSD
powerlifter405 is offline
post #2 of 9 (permalink) Old 12-12-2005, 12:16 AM
Re: carrier bearing / center bearing squealing got any ideas
i had that squeak too ... replaced the carrier bearing and all is well
thomas
<font color="orange"> __________________________________________________ _____________________________</font>
aka Power-Strokin' (234 posts)
<font color="navy">3.73ls VDH2 oxford white/silver metallic, DP-Tuner 4 pos.(40, 70, 100, 125), FTVB, AIS, WD Turbo Brake III, 4" Magna-Flow turbo-back exhaust, wicked wheel, 3 guage A-pillar pod w/ Di-pricol white-face guages, ITP fuel system, after market leather seats (two tone), Super-Liner, "chromed" emblems, CCV mod., BFG AT 295/75-16 on 16 x 10 Ultra Type 50/51 wheels, Rancho RSX, Amsoil bumper-to-bumper, PopUp GN hitch, GOS harness & SilverStars </font>
'04 F250CC Lariat PSD FX4 white/silver, Putco stainless toolbox, stock!!!
AllStarPSD is offline
post #3 of 9 (permalink) Old 12-12-2005, 12:27 AM Thread Starter
thomas
I noticed it some time ago and it appeared intermitant however I have no idea how long it had actually been doing this. i just happened to have the windows down and the radio off. Should I be prepared to have any drive shaft work done. Also, any difficulties in the job? Thanks for the input.
sold
post #4 of 9 (permalink) Old 12-12-2005, 12:39 AM
first off, before you remove any of the drive shaft mark all the pieces so you can put it back just as it came off. while i had mine apart i went ahead and replaced all the u-joints (get the kind with grease fittings). i wish i had gotten my driveshaft assy. balanced while i had it off the truck. not that i noticed a vibration, but just for peace of mind.
thomas
post #5 of 9 (permalink) Old 12-15-2005, 09:54 PM
This is the TSB for your problem:
Article No. 03-22-2
NOISE - DRIVESHAFT CENTER BEARING NOISE - VEHICLES BUILT AFTER 6/1/2002
DRIVESHAFT - DRIVESHAFT CENTER BEARING NOISE - VEHICLES BUILT AFTER 6/1/2002
Publication Date: October 17, 2003
FORD: 2002-2003 F SUPER DUTY
ISSUE:
Some 2002-2003 Super Duty F-Series vehicles built after 06/01/2002, with a multi-piece driveshaft may exhibit a squeaking and/or squealing noise from the center bearing while driving. This noise is produced when the bearing seal rotates in the bearing outer race.
ACTION:
To service, replace the center bearing. Use a center bearing assembly with a white paint dot (built after 6/9/2003). Determine the style of the driveshaft per (Figure 1) and (Figure 2), then follow the appropriate Service Procedure below.
SERVICE PROCEDURE
NOTE: WHENEVER DRIVESHAFT REMOVAL IS NECESSARY, IT IS IMPORTANT TO PAINT MARK THE DRIVESHAFT TO THE TRANSMISSION (OR TRANSFER CASE) AND THE REAR AXLE. ADDITIONALLY, MARK A PAINT LINE THE ENTIRE LENGTH OF THE MULTI-PIECE DRIVESHAFT ASSEMBLY. THIS IS ESSENTIAL TO INSURE THE DRIVESHAFTS ARE REASSEMBLED IN THE SAME ORIENTATION AS ORIGINAL. FAILURE TO REASSEMBLE THE DRIVESHAFT IN ITS ORIGINAL ORIENTATION MAY RESULT IN AN UNBALANCED DRIVESHAFT CONDITION.
F81Z-4800-FA
F81Z-4819-AA
E4Hz-4A254-B
F81Z-4N272-AA.
'02 F-350, auto, 4wd, 4:10, CC, DRW, LWB, Lariat, ISSPRO x 5, MBRP 4" SS, AIC, AIS, DTLS, BriteBox, Red-Head steering gear box, coolant bypass, 203 t-stat, 6.0 cooler, 120k... mostly stock but strong, pulls and hauls whatever I ask!!!
Fastcolts is offline
post #6 of 9 (permalink) Old 12-17-2005, 12:25 AM
I just picked up my truck from having the carrier bearing replaced. The bad news it was not covered under warranty. When I bought the truck I was told from the fan to the differential was covered by a 100,000 mile warranty. Now the dealer says only specific parts are covered. The carrier bearing is not one of the parts. The fact that there is a TSB makes me wonder if they purposefully excluded this part from the warranty.
BS like this does not build customer loyalty. [img]/ubbthreads/images/graemlins/mad.gif[/img]
2003 F250 Sport 7.3 CC SB 4x4, 99,000 miles, AIS, 315/70R17 BFG All Terrain TA
Chuck_B is offline
post #7 of 9 (permalink) Old 12-19-2005, 04:04 PM Thread Starter
Thanks for all the info on this. All the local stealers refuse to cover most anything on these after 36K. If I could work w/ the dealer out of SA where I picked it up then so be it but thats not the case.
I ordered a new one and it's cheaper and less of a hassle than trying to get the local theives to work on it. www.parts.com I"ve ordered a few parts here before and they are always extremely helpful.
Thanks again for all the help guys!
edited to eliminate scrolling problem from long url
post #8 of 9 (permalink) Old 12-19-2005, 05:06 PM
klhansen's Avatar
My Photos: (180)
That's what you get for listening to a salesman. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Warranty is 3 yr/36k mi bumper to bumper and 5 yr/100k miles for the Engine (and a few other parts like fuel pump), no matter what the salesman says.
A good dealer would have covered it for you if you weren't too far out of your 3/36 warranty period. [img]/ubbthreads/images/graemlins/frown.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #9 of 9 (permalink) Old 01-22-2011, 01:56 PM
Muddinf2501999's Avatar
Good info on the TSB guys! I'm doing mine today. Any tips on removing the old CB? I'm planning to use a cut-off wheel and "score" the bearing / race until I can split it w/o cutting / nicking the shaft.
'99, 7.3L PSD F250 4x4 SRW
Mods: BTS Tranny!!!!, Rockwell 2 1/2 ton axles, Goodyear MVT 395/85R20's and Schaeffer's Oil
'02, 7.3L PSD 6spd F350 4x4 DRW CC
Mods: IH Bellowed Up-pipes, 4" MBRP Turbo Back Exh, B&W Gooseneck Hitch, Michelin LTX A/T2 235/85R16's and Schaeffer's Oil
Muddinf2501999 is offline
