cat conveter law - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 09-19-2010, 12:53 PM Thread Starter
dtsthx's Avatar
cat conveter law
my truck is do for reg and utah has a catalytic converter law if i have a CA emissions truck than i think i need one ? do thay make a 5inch cat
how do i find out if my truck is CA emissions?
2001 F-350 larait c.c. s.b. 4x4 auto, keenwoodkvt915 in dash dvd 7inch screen ,1 alpine Rtype 12 woofer 1500 watts,pheniox gold mono block class d amp, scorpion BOX, level kit,mr taillight foglight highbeam kit, stock ford 18's on contie's, rancho 9000ES shocks ,6.0 transcooler, derale trans pan ,ccvdiy mod ,zoo dad , powerstrokehelp.com FUEL mods , hood insulation delete ,foil delete , high presure oil x pipe,
DP tuner F-6 = 900rpmEBV, drive-thru tune ,EBV Engine brake tune,40tow ,60 econo, 80econo , supersmoke (use with OD) , 100hp, 120race 140agrresive
, 3 pilier pod , pyrometer, 2trans temps inside tranny/outside ,boost,
diy cold air6637 & 45 degree 4 inch alum.8"x8" , JEG'S 4" downpipe to 5" exhaust flopro 6"tip
, dfuserA.I.H.plug, Extreme diesel Xwheel ,
(commin soon banks technicooler )
dtsthx is offline
post #2 of 9 (permalink) Old 09-19-2010, 01:33 PM
I would bet is boils back to if the truck had a CAT on it from trhe factory you will be required to have one for emissions. For instance my 2000 Excursion did not come with a CAT but I believe the 6 speed trucks did in 2000. So, I would not be required to have a CAT but the 6 speed truck would.
Beast is offline
post #3 of 9 (permalink) Old 09-19-2010, 02:04 PM
468LC's Avatar
To the best of my knowledge your truck should not have a cat on it.
I am sure someone will correct us if wrong.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
468LC is offline
post #4 of 9 (permalink) Old 09-19-2010, 02:29 PM
Banned
mine has a sticker on the hood (NON CATLIST) It is a cali truck. It has no cat.
ARMSTRONGFORDTRUCKS is offline
post #5 of 9 (permalink) Old 09-19-2010, 04:04 PM
SmokeyWren's Avatar
My Photos: (45)
2001 F-350 larait c.c. s.b. 4x4 auto (diesel)
That truck did not come from the factory with a catalytic converter, regardless of which emissions pkg it has. So you shouldn't need to worry about it. If you're in a state run by the greenies, they sometimes pass stupid laws. But they would have to be really world-class stupid to require you to add a cat to a vehicle that didn't have one from the factory.
SmokeyWren is offline
post #6 of 9 (permalink) Old 09-19-2010, 10:24 PM
There is some really stupid people out now days
02 PSD Lariat CC DRW, 4X2, A/T, 4:10, Big Tex grill guard ,115 gal in bed fuel tank (switch on the go) ,5er notched in bed tool box, Reese 5er/gooseneck/bumper hitch, 20K fan powered under cab tranny cooler, AFE intake, Super chip, TC lock up, Gear vendors exhaust brake, 4 inch turbo back exhaust, oil/water/egt/boost/tranny/diff guages, CB radio, Back up camera, Air bags (inside cab control), Mag-hytek tranny/diff pans,, Ram tough computer stand, FS2500 Aux Oil filter, Turbo life saver, Turbo Master wastegate actuator
Fordpowerstroke350 is offline
post #7 of 9 (permalink) Old 09-19-2010, 10:50 PM
468LC's Avatar
Yes, yes there is.
Steve
468LC is offline
post #8 of 9 (permalink) Old 09-20-2010, 02:59 AM
lance1955's Avatar
Arnt they in Washington?
2002 Excursion 7.3L 200K+, After market tranny cooler, diesel site transmission filter kit, coolant filter kit and complete boot kit, bilstein shocks. Original transmission with mobile syn ATF
lance1955 is offline
post #9 of 9 (permalink) Old 09-20-2010, 07:59 PM
And anyone else that votes for a democrat
03 f-350 cc 7.3 4x4 edge evolution, afe intake 4 in turbo back exhaust
97 f-350 cc 4x4 sc tuner, dieselsite electric fuel conv.
firman is offline
