changing brake line question - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 05-25-2006, 02:44 PM Thread Starter
NCHornet's Avatar
I will be changing my front lines to stainless steel wrapped in Kevlar tomorrow. I was looking at the hoses today while changing my shocks, the lines go from the caliper to a mounting braket on the frame where there is a junction to another line. It looks like there is a large C clip on the back side of this bracket and a small one on the caliper side, but the hose has a nut on the caliper side. Do I need to mess with these clips or can I simply loosen the nut from the caliper side of the bracket. I have never messed with brake lines before, done lots of brake jobs but never had to replace a brake line, Thanks Ford!!!
Also in 2000 did they have 4 wheel ABS? I noticed three lines going to my caliper assembly, one is the brake fluid, one is the vacume line for the 4x4, but I am not sure what the third is, maybe ABS sensor, or a speed sensor?
I thought I just had rear ABS but I could be wrong.
Thanks for the help.
Kevin
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #2 of 12 (permalink) Old 05-25-2006, 04:30 PM
griffy71's Avatar
Re: changing brake line question
My 01 has three lines and 4wheel ABS. I can confirm the third line, because I accidentally ripped the wire out of the sensor doing ball joints.
Griffy71
Necessity is the mother of invention.
If it jams, force it. If it breaks it needed fixing anyway.
01 F-250 PSD 4x4 Extended Cab, Bully Dog Chip, Homemade Tymar, AIH delete, Fumoto Drain Valve, Wicked Wheel.
griffy71 is offline
post #3 of 12 (permalink) Old 05-25-2006, 06:15 PM Thread Starter
NCHornet's Avatar
Is there anywhere on the door sticker that will tell you if you have ABS?
How about taking apart that brake line connection? The parts will be here tomorrow.
Kevin
NCH
NCHornet is offline
post #4 of 12 (permalink) Old 05-25-2006, 07:03 PM
klhansen's Avatar
My Photos: (180)
AFAIK 4W-ABS was available on all Superdutys. That 3rd line is the cable for the front wheel abs sensor. If you follow it up to the frame there should be an electrical connector.
), AIS,
regulated return,
klhansen is offline
post #5 of 12 (permalink) Old 05-25-2006, 07:07 PM
They were definitely available on 2000 models. I have them on a Jan 2000 truck.
444-4D is offline
post #6 of 12 (permalink) Old 05-26-2006, 08:08 AM
If you have three lines you have ABS. I have a Y2K without ABS and have two lines.
2000 F-250, 4x4 XLT shorty CC, AT, Isspro trans/pyro/boost, TTM, SCMT, AFE, HX, 203 Thermo, Sonax/Tricum, 4 1/2" Donahoe lift with 315/70/R17 BFG AT's, 4" MBRP T-304 SS exhaust, Coolant filter, non ebv ped, non ebv outlet, noisy ass garrett bb turbo, DI uppies
freestroker is offline
post #7 of 12 (permalink) Old 05-26-2006, 11:00 AM Thread Starter
NCHornet's Avatar
Good to know I have 4 wheel ABS. I got the new brake lines in and it is pretty clear how the connection comes apart.
Y'all
NCH
NCHornet is offline
post #8 of 12 (permalink) Old 05-26-2006, 02:48 PM Thread Starter
NCHornet's Avatar
Update:
For those wanting to do this, the new clips are not like the ones Ford uses. The new ones are a simple C clip. With Ford's you must first disconnect the brake line, then pry the top of the clip off the nut while then sliding towards the other side. A real pain and a piss pour design. A simple C clip would have been fine!!! The new lines are awesome and work great!!
NCH
NCHornet is offline
post #9 of 12 (permalink) Old 05-26-2006, 02:52 PM
Make sure we get to see some pics of the finished product [img]/ubbthreads/images/graemlins/smile.gif[/img]
2001 F350 extcab 4x4 (My truck is slow)
powerstrokenation.com
My Cell: Questions, comments, cuss me out, 734-652-7639
freddyfast9 is offline
post #10 of 12 (permalink) Old 05-26-2006, 03:26 PM Thread Starter
NCHornet's Avatar
I will try and get some up this evening.
NCH
NCHornet is offline
post #11 of 12 (permalink) Old 05-27-2006, 03:16 PM Thread Starter
NCHornet's Avatar
Placed some pics in my album today, enjoy!!!
NCH
NCHornet is offline
post #12 of 12 (permalink) Old 05-27-2006, 03:22 PM
Real nice and how does the pedal feel? The beauty of the ones you have is they are kevlar coated so they won't frey.
